View Full Version : CRX & Pre '92 Civic
- crx hybrid
- Seeking '90 Wagon AWD Rear Link Bushing
- question about wheels?
- Whats going on?
- Seat belt warning buzzer
- my 89 civic SiR
- stripped oil pan...
- brake upgrade
- Gauge Cluster Lights Problem...
- can a accord a/c control unit fit on a crx?
- do i need it
- exhaust
- Intake manifold torque spec
- Anyone?
- Anyone bother to add a extra seat ont he back of the crx?
- CRX HALO PROJECTOR HEADLIGHTS on ebay
- Crx Si intake manifold and throttle body& Injectors work on a dx model?
- Got a few questions.
- Just curious of what you guys think of this buy.
- dx to si
- Having a hard time removing the oil pan.
- throttle lag?
- j1 intermediate shaft, y1 tranny
- :ghey: CRX died today NO SPARK!!!!
- can any turbo fit on a crx? modified ofcourse
- 90 Civic Blower Problems
- problems?
- Engine smoke
- Rear Brake Conversion
- does the 02 sensor make the car run whacky if its gone bad?
- would garrett t-3 turbo be easy to put in a dx crx?
- CRX wiring help b16a
- how do you take off a tranny oil fill plug/bolt if it has been rounded?
- can a accord ex engine work in a crx body?
- anybody have stock passenger side headlight wires? and stock radio wires?
- someone should make the "official 1/4 mile timeslip thread"
- Whats the cheapest but good shock and struts for crx?
- web site
- replacing 90 crx a/c control, can i use a 94 or later?
- Car is running like crap
- chevy 350
- D16a6
- In need of motor mount for 86 crx b16 hybird
- Finding all the parts...
- pros & cons to v-tec swap
- is it worth changing an auto to manual with HF tranny?
- civic tail lights
- 1/4?
- how do you take off those side skirt things? those black plastic things?
- How Low?
- vtec head
- 89 civic white si hatchback!!!!!!!!!!!!
- Coolant leak????
- 1989-1990 Vtec CRX integra Japan exporter
- battery relocation in the back of my car
- 02 Sensor
- tranny swap done. motor wont crank? i need help
- what do you think it will run
- computer
- oil light
- Headlight question
- 95 Accord crankshaft bolt removal
- Downhill stalling
- To turbo, or not to turbo...
- i started my 5 speed tranny swap today and...................
- my rex died
- I need a muffler!
- CRX starting problems
- i have a a big problem...please try to help..
- 95 LS Swap into 90 CRX HF SWAP Help Needed
- 99-00 civic si Lip install on crx bumper (pics)
- whats obd/1/2? what is that stuff?
- swaps
- CRX for street/mostly track...what to do for 3 grand?
- Ok, so now i'm really confused *oil burning*
- drilling...
- dx 2 si manifold swap?
- 91 ex seats into 91 hatchback?
- How do you like my custom work?
- bleeding breaks
- Window
- idle question
- Z600, anyone?
- 88-91 seat belt swap
- help quick please
- CRX Revival?
- Two things...
- 1984 CRX 1.5 cooling fan relay?
- Thinking of buying a crx or civic hatchback...
- How much for an install? rebuild?
- How many miles did you get?...
- would all this stuff fit? ef chassis, b16a, and vortech supercharger kit with afterco
- cant find aftermarket parts for 87?
- help...
- Water temp issues
- PG7 ecu trouble
- HELP ...valve cover gasket kit help!!
- charging a battery out-of-car
- 86 Crx
- b16b and h22
- need a crx 89 rear brake kit
- need tranny t bracket for a 1st gen b16a what will fit?
- Please someone I need engine help!
- Wiring help please...Diagrams needed
- whats a hydraulic tranny? whats a cable tranny?
- B16 question... please help
- Brown Top ZC...
- Need Help ASAP!!!
- 94 EX Brake Conversion: Why not use parts from 94 Civic with disc?
- Nor Cal CRXPO 2004 October 17th China Camp San Francisco Official Thread!!
- How can I be sure...
- Clicking? Clunking?
- 86 CRX Si swap
- need trim fast
- EF/honda MEET SOCAL (CHECK ME OUT)
- Replacing exhaust system: 91 CRX
- ECU error code 12 (egr system faulty)
- do racing chips on ebay really wor?
- Spare Tire Sub Box?
- Any tips?
- d16a6 tranny on d15b1, what is needed from the ex?
- ex gauge cluster in 91 standard hatchback?
- CRX Convertable?
- Ran outta gas now wont run
- need rear disk breaks for crx hf, what will fit
- 84 dx tran linkage
- Tranny swap
- steering boss?
- 2006 CRX SiR Ad
- Idle Trouble
- CRx Wings west flush mount spoiler, opinions
- Can't drive past 3000 rpm!
- my ef in progress...important
- Electrical problem with 91 civic hatch - Help!!!
- Post Pics Of Your Ef9
- crx gauge cluster
- MAP sensor & EACV
- Edit
- 86 Civic Si - ECU
- tranny
- Wtf
- jdm front end
- B16 CRX Vs. Modded GTI Video
- replacing/upgrading springs and shocks in 87 HF CRX
- CRX with an Acura motor..
- and so it begins
- d16 with vtec head
- Paint ???
- PLEASE LOOK and hopefully help... turn signal problem
- big brake kit
- 90 dx hatch drifter
- crx ls swap
- Turboin' my LS VTEC swap Need help?
- Need an alternator for a 90' teg
- OH SNAP!!! i just got a EF, 91 civic std hatchback, but...........
- 91 dx sedan wont start
- Exhaust vibration
- kai, as a reference to Keisuke, who ALSO drives an RX-7?
- cap and rotor
- mini me question....
- clutch
- Curse of the distributor
- crx engine question
- Tranny trouble
- Weird cat...
- WANTED: PM6 ECU for CRX Si
- Annoying Squeak!!!!!!!!
- Skunk 2 Intake Manifold????
- Fix it or trade it?
- fun without money?
- wheels?
- What header to use for zc
- steering ratio?
- suspension compatibility
- Guage cluster
- Damn welded parts!!!
- shift linkage in 91 si
- Well guys, the Honda bug bites hard.
- Engine/transmission compatibility question
- B16 swap question
- help with fuel filter
- 91 hf crx.....motor???
- crx carpet
- mid pipe question
- noob ?
- civic wagon 4wd
- Newer civic seats fit?
- WANTED: CRX SI 88-91 High performance cat back exhaust
- Losing Antifreeze
- Quick PCV Valve / Valve Grommet Question
- D-series flywheel bolts on Bseries flywheel?
- What do you think? My CRX Turbo SI
- Help, Fast!!!!
- obd-1 Distributor
- 1990 Civic Auto transmission costs
- 90 Civic EX slowing
- New Shoes!!!
- Air Conditioning
- Radiator Removal/Installation.......
- ECU Question....
- need flywheel bolts for b16
- B16A JDM cams VS 97 GSR...
- Front end swap
- emissions
- Looking for a Quiet Exhaust.
- one more timing belt question
- please help!!!!
- hopefully gettin a crx
- whats heavier, 90 std civic hatch or 90 crx hf? or how much do each of then weigh?
- 90-91 usdm cluster in 88-89 civic
- Socket for Crank?
- reverse lights on auto to manual swap
- slipping clutch
- snapped cam holder bolt...
- bypass?
- f22 help
- roll cage for a crx
- fiberglass nose panel
- whats a ZC?
- Radiator Help!!!!!
- where to get roll cage for '90 civic?
- bypass clutch relay on swap
- need some help!!
- getting close
- Interior work
- hey kia
- 91 Crx Si
- hey kia
- jdm climate control in a 90 crx?
- Skid Plate for crx
- 86 civic si sputters and/or dies and won't start at times
- man I sound like a ricer
- crx hf 3k?
- crx all 2 passenger cars?
- how to take off ac help!!
- skunk 2 intake manifold
- Intake manifold whistle
- Need'91 Fusebox Diagram - please help
- Friendly Wager
- Vacuum on the Si intake manifold
- Help, hatch leaking
- 90 Automaic D15 Linkage removal
- dx head hf block
- Shifter and bushing install
- crx si and civic dx wiring question..........
- lowering question?
- b16a question
- b16a exhaust questions
- Y8 head on D15B2 question
- Vin Run
