- dohc zc
- dream wanna come true
- Tranny fluid question
- Which CRX for a d16y5 swap?
- need to know
- bad gas mileage
- Best way to remove...
- well
- what to do next?
- D16a ???
- crx engine question
- Cracked head and /or gasket?
- please help
- cutting the fat
- Sorry Guys
- This is what happens..
- singal light question
- help.crx problem
- trouble with heat
- ouch
- Time for the big swap B16 Sir into 88 Crx Si
- whats dizzy
- am i bing lyed2
- 91 Civic burning oil
- Ls Crx
- Any Info On The New Crx
- Performance gauges
- HF Hubs work with ZC swap?
- rear sick questions
- EDM suspension
- new bushings after rear disc swap...
- transmission or clutch probs???????/
- Opinions... CRX or RSX?
- PIcs of my pink crx!!
- Fuse Box Diagram???
- H22 into 89 Hatchback?
- 1988 honda crx startup failure/fuel pump inop
- boost d15
- jdm versus usdm for 89 civic dx
- good price?
- ZC foreign to me
- integra headlights
- 86 crx rebuild
- VTEC or speedometer which would you choose?
- B16a ?
- Check check double check
- Noisy in 1st and 2nd gear(tranny bearing or shift bushing?)
- crx nightmare
- What engine in 88-91 CRX?
- B18A1 wiring help.
- What exhaust is best for crx with b18c1?
- CRX:B18A1 help
- 90-91 crx front bumper on 88 crx
- fog lights for 90-91 crx si
- How Do U Find Out About The Genration Of Ur Car
- Car Is Knocking
- I Need Help With My Ef
- going to get some rota slipstreams need some advice
- 1987 batttery light flickers
- civic boost setup
- 91 Crx 1.5 Tbi Stalling In Accelerated Corners--might Stump Even The Best- Please Hlp
- crx shuts off after warmed up
- honda civic 86 wont hold idle
- 91 CRX HF with 1.6 swap throwing a ton of codes, stalls, runs terrible
- loose hatch...
- vin check?
- Auto to Manual
- 91 CRX stolen and stripped
- Reintroduction/ introduce yourself
- what is the potential of a 89 Honda CRX SI?
- I can go up to 10 mph at idle while in drive. What is the problem?
- EF9 JDM SiR front end questions
- b16 speed sensor
- Does my 89 Civic DX 3 door have a cabin filter?
- 88-91 jdm sir civic sedan 1 pc headlights
- clutch
- my 90 civic wont start
- s2000 cluster in EF
- Please help!!!
- suspension problems
- b16 T3 super 60 in Crx si
- 88 CRX, 93 integra rear disc conversion question
- teg gauges
- ls/vtec help in 88 crx wiring
- vafc setting
- 85 CRX sunroof issues
- 90 Civic 4 sp manual tranny swap to 5 sp
- Tach. Question
- whast size turbo??
- Fuel Pressure?
- installing an engine question's
- please help!!!!!!!!!!!!!!!!!!!!!
- 1985 Civic CRX restoration
- timing belt broke
- ukdm cluster into us crx?
- what should be done
- 90 civic hard start????? 73K
- b16 or lsvtec?
- change obd0 to obd1
- main relay???
- Replacement front coil springs for a 91 4 door civic
- Need turbo set up help
- What motor should i use?
- Curb Wight comparison
- 86 crx hf swap help
- suspension?
- 91 civic
- B16 Running strange?
- CRX Sputtering After Warm
- i can not locate the flasher for my 91 CRX Si.
- higher mph speedometer
- Never worked on engines before and...
- Crx swap?
- B series clutch....
- rear water leak?
- zc help needed, transmission
- What parts from an integra will
- Floor Mats?
- civic motor in crx?
- Exhaust running rich!
- what is this sound
- Clutch Replacement Instructions on a 90 Civic Sedan
- water leak
- Help! Car just died!
- 2nd Gen versions
- B18C1 Turbo or Supercharger?
- My brake light comes on when i Drive
- s1 to a1 tranny???
- d16a tranny on a ZC longblock?
- Help my Turbo ZC wont stay alive.
- 88-91 crx side marker install. HELP!
- lookin for an exhaust
- 87 crx needs floor pans and rear quarter panels
- B16A Motor Mounts
- Conversion to Manual Gearbox
- 86 civic needs choke to start...why?
- my 1990 crx
- Lowering Question????
- Help...NO BRAKES!
- What does everyone do for exhaust?
- '89 Civic/Integra Experience Needed: Cold Rough Idle
- mechanic in oc/so california?
- Best tranny for ls vtec
- Car Stales are low RPM
- Grrr... Transmission
- Project Help Needed.
- CRX Fuel Pump Mess Plz Help
- trouble shifting into gears
- are the rims a good deal???
- Retaining Spring Info ?
- Is this a good deal?
- *****in Desperate Need*****
- B16 in CRX Swap info?
- Is It Possible?!?!?!
- Wiring HELP!
- seat questions
- 91 civic hatchback in a 92 4dr civic
- Redline?
- Electrical Problems
- LMA help needed
- Radiator change 90 civic si
- Starts then immed. dies...
- Front Hubs?
- Will parts from a 90 dx hatch fit..........
- How tough to instal AC
- 92 auto tranny into 89 ef ??
- Honda Noob Intro.
- timing belt covers
- need help finding good turbo kit for crx
- CRX hatch
- why is my engine ticking still?
- LS/VTEC turbo setup...
- Tac hwiring on 88 civic...
- exhaust manifold interchangeability with D16A6
- diff in the B20
- my plug is stuck!!
- 1991 Integra D16 in 1990 Honda CRX Problems & Halfshaft Damage
- 89 crx opinion
- 6-speed+crx?
- ground wire question
- 1991 Civic w/ B18 Swap Issues...
- Anyone EF experts in Northern VA area who can help me?
- 5 speed question HELP
- help with b16a swap
- Engine build up?
- 87 Civic Timing?
- crx v-tech conversion
- Gas Leak!?
- Throttle valve not smooth (D15B2)
- noob exhaust question
- crank puley help
- Broken CRX
- 90 Civic DX?
- 1990 Integra/Civic 4 door question
- d16a6/ d16a1
- Tightening Steering Knuckle
- 90-91 rex taillights on my 89 betsie
- tming off on the d16 a6
- Main Relay.
- 1988 Crx
- sway bars
- 3rd gear grinding
- Radius Rod Compatibility
- Timing Belt Tensioner and Water Pump
- back seat for a crx
- B16b Crx
- ls/vtec or k20 swap into crx???
- brake question
- Weird Clicking Sound in Steering
- Dashlights are dim
- A good deal?? 2 CRX's?
- Planning B18C5 Swap In '91 Civic Si
- Major Tuning Help
- Cigarette lighter installation?
- 93 DX air conditioner ground?
- Clutch in 91 Civic
- none v-tech motor with with v-tech head?????
- Zc Questions
- Stolen: 1991 CRX Si (san jose, california)
- What engine will fit into my 86 CRX non -si!!
- Crx Problems!!! Help?
- 90 civic dx engine question?
- what year again is the 'odd' year for 2g CRX's?
- Question on mounting B16A2?
- Gas
- New member Intro
- rear dsic conversion on a 1991 ef hatch
- random death of '89 Si
- can i get a little help
- 1990 Crx
- 88 crx dx manual won't start when hot
- JDM OEM Skirts?
- Bolts for my rims
- cel help
- B16A O2 sensor wires?
- New Member New Car
- Help!!! temp and fuel gauage is not working
- main relay check
- need conversion help
- Problem with Neuspeed Strut Brace and B18a
- dash help.
- To Turbo or not to Turbo?
- is my timing messed up or what?
- ??? rev limiter at 3 grand something not right????
- Lug Nut Socket??
- Turbo feed/return lines
- Fuel filter
- coolant tank blew up
- wanting to install a hidden kill switch..
