clutch
Old Nov 30, 2006 | 06:46 PM
88'CRX's Avatar
88'CRX
Default clutch
alrite i was driving home from work today and something happened... i was going fine down the road in 5th gear until the car in front of me started to slow down to turn.. i pushed in the clutch and just coasted for a sec till he turned... when i started to let out the clutch to start goin again it was weird.. the friction point was a lot closer to the floor and after the clutch seemed fully engaged and i was letting the pedal out the rest of the way the pedal gave me a grinding vibration type feel... now it does this all ther time... the friction point is like a half an inch from the floor and the clutch just seems really loose.. does anyone know what happened????
Old Nov 30, 2006 | 07:39 PM
18crx's Avatar
18crx
stock booster
humm all of a sudden then bam it isnt the same..
well the best thing is to stop driving it so if theres more than just the clutch thats bad u dont mess it up also.
is it grinding and vibrating when u let it out or just vibrating. possible a broken spring on the clutch disk.
i assume ur car is a stock car what model. si hf dx
any history on the car before u got it.
any way u look at it probaly have to yard the trans out. what state u live in.
Old Dec 1, 2006 | 08:51 AM
Tankard's Avatar
Tankard
Check the external things first before removing the tranny and checking the clutch disk itself. For example, check the clutch cable mounting point at the firewall to be sure it's not broken, and also, check the clutch pedal pivot point to be sure it's not broken. Also, try adjusting the cable at the tranny.
If it's not what i said, it is more than likely a broken clutch disk spring like posted above, which will require dropping the tranny and replacing the clutch disk ,pressure plate, throwout and pilot bearing. A clutch kit can be bought for around 150 bucks. It's the labor that will cost you if you can't do it yourself.
Old Dec 2, 2006 | 01:00 PM
88'CRX's Avatar
88'CRX
ya it just happened all at once but i believe its just vibrating not grinding.. no i actually have a b18a swap but no history about the car from before i had it
Old Dec 2, 2006 | 11:35 PM
tommyhcky13's Avatar
tommyhcky13
get a new flywheel or get yours machined if you do the chutch
Old Dec 5, 2006 | 11:56 AM
88'CRX's Avatar
88'CRX
alrite just talked to my mechanic and he said that i will have to replace the clutch... anyone got a website or link for a good new clutch kit or even a racing onefor a b18a????
Old Dec 5, 2006 | 02:17 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Stock Clutch kit will work just fine
Old Dec 5, 2006 | 05:44 PM
88'CRX's Avatar
88'CRX
websites for one??????
Old Dec 5, 2006 | 06:48 PM
18crx's Avatar
18crx
stock booster
u plannin on doing any power adders. if so maybe a little better clutch if not sotck and what tranny do u have make sure to count the splines before ordering the clutch that way u know what one to get.
Old Dec 6, 2006 | 03:35 PM
88'CRX's Avatar
88'CRX
ummmm... splines???
