View Full Version : CRX & Pre '92 Civic
- Code 9
- my crx..new to the forum..
- 1991 Civic 1.5L Rear Main Seal Replacement
- thud sound
- 91 CRX hood fit anything else
- how to identify hf tranny 88 crx
- wireing diagram
- d16a6 head on a d15b7 block
- crx h22a redtop
- D4 blinking after engine swap on '96 Civic
- Driving over 200,000 miles
- I have some questions about a turbo kit
- 89 Civic Si - CEL code #5, dies after 20 seconds
- the difference is???
- need assistance...
- Has this ever happened to you?
- upper control arm anchor bolt
- CRX Si GSR Swap questions, please help
- Front brakes overheating....Need help
- Crx swap: opinion needed
- Will this fit?
- rear suspension
- front motor mount ?
- CRX rpm problems.
- 89 Honda Civic tail light fuse keeps blowin??
- problem going on its like its bogging
- will 92 integra cluster fit 90 si
- Never ending REX
- Niagra 14 CRX meet pics
- single tranny
- Need help with a 90 CRX, A mystery to me, Maybe you can help solve
- starting issue 90crx
- 91 Civic Bogging Issues
- Motor and Trans Help?
- suspension swap for crx
- need help on gauges
- 91 civic 1.5 wont start just chuggs
- Fuel Injection Relay Location?
- SSR MK-III's
- dx or hf?
- Clutch won't disengage.
- Sir2 B16 In A EF?
- Cold Squeal
- Engine Compartment Fuses ??? 87 Si
- Bushing Interchange ability
- Brake problem
- CRX Help
- Gauge cluster problems-Will this work???
- Crx b16a Trouble shooting?
- code 17
- 91 civic no start ( tech chime in please)
- Radio Help
- idle revs up and down
- Something blew, maybe a seal?
- EF9 civic from malaysia, with EF8 crx front
- Air conditioner
- brake lights stay on
- Problem with stereo system
- Moonroof for '90 HB?
- omg clutch
- No power to ANYTHING good battery
- crx bumpers
- 1989 civic TPS/TAS
- looking for....ugh...ZC motor
- Is there a rebuild kit for a 1986 HF carb motor
- freeze12
- 86 Civic DX Wagon 1.5L NEED HELP!
- rims
- Dohc Zc
- EF Hatch vtec wiring??
- A/C compressor from other models?
- What's some sites ?
- Electronic guru needed: wiring D15B2 from scratch
- 89 Engine Swap to Acura
- Wanted:: ECU/wiring for 88-91 DX 1.5
- Crx electrial problems
- fuel rail leak
- New guy needing engine ID help
- crx heater control in hatch
- 88 hatch
- D16a6
- starting problem
- Odometer & Climax control light bulb !
- just bought a ukdm cluster will this work on a usdm?
- Swap options for a 1st Gen CRX
- Removing rear bumper on 91 Civic hatch
- B16 start up
- Crx b16a1 axles and clutch
- Spring help
- b16tranny rebuild
- 88 crx short shifter to a 87crx
- question about 89 crx
- h22 into a 90 ef civic, what do I need besides the obvious?
- 86 CRX Si bogging/hesitation/staggering
- B16 Tranny
- servicing a 89 honda transmission
- temp gauge sending unit
- Engine Help
- Fuel gauge problems
- 89 crx engine swap help
- What do i need for a B16A1 swap in a 91 crx Si
- Alternator in 91 Civic?
- '90 Civic motor/head question
- Painting the rex
- keeps bogging out
- 89 crx engine swap head help
- Turbo D15A3?
- 88-91 CRX Si front bumper install
- Stripping parts for parts and profit, Ideas?
- car stalled out
- 88 hatch vs crx
- what do you think
- Transmission fill Plug
- ls build for forced induction
- 91 DX needs pass. side axle and tie rod
- Tps For 88 Crx Dx D15b2 Engine
- unlimited revving on '90 Civic HB
- inner tie rod replacment sint going to well
- civic broke down
- 89 CRX SI water pump removal and install problems
- y8 on a 92 civic
- CRX camber kits
- make my car honda faster
- 87 CRX Fender dim
- rear window wiper blade issue
- 88 CRX Project???
- crx brake differences
- crx throttle body
- 4wire o2
- Body Kitz
- can a 5g civic cluster b installed in a 91 hatch?
- looking for a honda in erie pa
- 1987 CRX Bumper
- 91 CRX Swap problem....
- Electrical problem 87 CRX SI fuel injector system
- seat swap
- dual-port to full fuel injection help
- piggie back
- Civic fenders on a CRX??
- what is a mini-me
- how do i take my axles out
- hydro lock help
- 30 per gallon
- what do u prefer?
- how to fix code eight and nine
- 91 Civic LX power surge at Distributor
- what would u run a na car with?
- swap help
- Need help plz, Fuel filter?
- fixing error code 20
- 93 Honda civic Axle.. HELP
- help I need to replace a struts
- ignition switch help
- B16 vtec engine will B18 header fit
- 1987 CRX fuel pump not working
- labjunkies
- 1986 Civic ....poor fuel economy
- clutch rod
- add a cold air intake
- headlights
- Rota Slipstream in 15x8"?
- I Have b16 on 89 crx have question on radiator and y fan wont start
- My K24 CRX ITBS Restoration.
- making ecu jumper ?
- ef b18ls right hand drive
- crx exhaust
- crx which swap
- Pics of various wheel sizes and drop amounts
- wrong oil plz look?
- error codes?
- Bad gas mileage
- d15b1 mini-me?
- OBX Differentials
- No Reverse after tranny rebuild
- used 92 civic
- 90 honda civic having wiring issues
- engine shuts off
- ??? engien mounts form a b16a
- Stripped head bolts,d16a6
- PM6 with B18a1 in "91 civic dx??
- Auto Trans fluid - 98 Civic
- Diagram of sensor locations b18a1
- Odd electrical problem
- 91 civic charging issue
- Max Performance Club
- 1986 Honda Civic poor fuel economy
- Swap question(mostly about Tranny)
- Wheel alignment
- 81 civic engine swap?
- CRX B16a1
- Considering a B16 swap but missing parts...
- Hazard fuse. Which one is it?
- Clutch problems before & after swap
- i got a 95 civic
- Which Camber Kit is Better!?
- 1990 CRX Body repair/replacement advice
- jdm s1 transmission???
- Should i go for the short throw shifter?
- New clutch install same noise!
- d15b2 - d15b6
- 88 Civic w/ZC auto tranny running rough
- Uti?
- Update: Gauge cluster lights stopped working...
- center console
- anyone know about auto transmissions
- Pilot bearing size issue/91 DX
- What MSD cap for B16A1
- a 91 crx si tell me what you think
- D-series block question
- Now no spark coming from distributor
- Gas Leak!!!On Line
- d16 turbo help
- distributor and carburetor
- new crx
- hoses Where do they go??
- Installing Sunpro H2O, Oil Guage, quick Q
- CV Boots Axle Shafts on 89 Si
- wide body q's
- My 89civic project, with Q's and pics
- ???crx sputtering stalling and intemittant smoke
- CRX Injectors not firing HELP!!!!!
- Can a fuse cause gauge cluster lights not to work?
- Parts from a ZC...
- si motor swap
- My dash gauge cluster lights stopped working??
- drivers side mount on d16y8
- Gear ratios 90 Si
- 1988 CRX fuel tank removal how difficult?
- i got Q's about a b-16 motor
- What newer parts bolt right up to a 90
- keeps cutting off
- light bulbs
- 88 Civic bogs bad!!
- headlights
- Security
- what ecu to put in my 91 crx
- Civic/CRX Bumper Fitment
- OBD1 Swap, frustratingly small issue
- ECU to IGNITOR
- Cluster Indeglo Overlay DIY 92 civic hatch.
- Please Help!!!
- My first stab at head porting...
- clutch problems
- b16 transmission
- 88 Civic HB Speedometer Doesnt Work
- Tuning up my 89 dx project suggestions please
- 1990 crx friendly drags
- wtb crx PA
- Sunroof problems.. wtf!?!?!
- crx tranny/clutch compatability???
