View Full Version : CRX & Pre '92 Civic
- tranny from b20a work with b18?
- b20z in crx ??
- Is the EGR valve pluged?
- clutch pedal stuck down?
- heater problems
- Built ZC complete swap on ebay!!!
- 84 CRX idling *really* low and stalling
- Egr??
- Looks like my CRX is going to be totalled
- lowering
- wanted crx
- Carbon fiber Crx Parts (Topshopheadliners.com)
- Help!...Overheating!
- si tranyn on zc motor
- wanted crx si preferably 91
- ls problems. clutch problems
- crx parts
- '88 Civic DX engine swap
- 87 si head swap
- my hatch wont latch closed
- sunroof problem... help!!!
- compatible heads with a stock 87 si block
- 91 DX stalls going 50mph...AND 10mph
- anyone with a CRX with H22A1
- pix of my new toy!
- Clutch break in
- Is this crx worth 5700 bucks?
- Mini me worth it or not?
- d16z6 into 88-91
- Nitrous, turbo both? Why where when and how much to use
- FUEL INJECTION or WHAT????
- Whats the difference between a ZC and regular engine?
- What engine to buy? Ran out of ZC
- Any 2nd gens out there?
- having car dynoed
- Vehicle speed sensor
- D series vtec head for 91 crx si?
- little bit of vibration
- 2 quick questions
- What parts from a 94+ integra can go on my hatch?
- people with seatbelt-beeping problems...read me!
- I need a what??
- how to fix the hoop opener?
- Radiator leak?
- diff between DX and Si tranny??
- Battery cable size, and leangth?
- H22a CRX's out there?
- CV joint AXELS
- revhigh online?
- Help, betsie is throwing code at me.
- tranny id??
- 90 civic vs 91 integra??
- 85 HF dies after warm up... why?
- 89' CRX won't stay on (my brain is running hot)
- Climate control?
- want to install sway bars
- how to wire in v-tec
- Anybody know what this does?
- mpfi conversion tube help - pics included - possible 56k warining
- brake pads
- Timing belt change interval?
- Suspention opinion,pads&brake pads
- Stock timing on b16
- 90 Rex Trany Help
- New??? Crx
- How do I check for codes? Engine lights comes on all the time
- oh damn, might be getting a crx.
- coolant temperature sensor
- Please help, Cracked head?
- New to the CRX world, have some questions
- Help! Oil keeps leaking and I replaced it twice
- What do you think?
- 91 DX cold air intake
- Genral but weird and off the wall question
- Intake coupler?
- The night from hell... help me fix my problem please :)
- B16 Performance
- battery?
- steeringwheel fitings
- I Want A Crx
- gingas,91blackSiR hatch
- Coolant temperature sensor
- Muffler?
- AEM hybrid intake system
- my temp gauge is out?
- MPFI problem (plz HELP)
- Crank Bolt relief, finally!!!!
- Speedo?
- Ecu Codes!!!
- Cam Help! (for all the crx junkies out there)
- Will stock tranny from 88 CRX work with D16y7 motor?
- MPFI Conversion HELP Please!
- A stupid Engine Swap question?
- Want to swap Canadian cluster...
- how much does a tune-up help?
- help need leg room
- FWD LSD is different from RWD LSD?
- FS;hasport mounts plus axels
- rallycross a CRX
- PCV valve to intake manifold question
- Can a b20b CRV motor bolt into an 88 CRX DX
- Anybody have an A/C with b-16a motor in CRX?
- Funny pic about rice burners and american muscle cars.
- cheap ebay b series engine mounts
- Mini me swap question
- Heater/Fan problem
- lower engine mount
- a few b16a questions
- 90 Civic Tail Light problem
- lip kits?
- Tachometer and Gas guage doesn't work
- Stereo wiring chart for crx?
- dpfi 2 mpfi question
- crx for sale
- tickling, tapping noise?
- I need serious help.. never seen this b4!!!!!!!
- Need Advise!!!
- B16 with B18 head? a couple questions
- Power steering
- Fastest or quickest Hondas ever?
- New Bie....... 91 CRX questions
- Dumb question about b-16a in crx
- honda trouble
- 900,000 Miles!!!
- my side marker lights (orange side lights) and tail lights dont work, only headlights
- 02 sensor locations need help please!
- How to install short shifter
- mpg?
- Zc
- Clutch cable adjustment?
- Gauge Question
- 88 crx kits fit an 87 crx
- alternator trouble
- D15B2 to B18C5??
- get b18 block or get b20 block?
- Serious Overheating Issues NEED HELP ASAP
- My car is smoking...n e ideas y?
- what's the cheapest best engine for my crx?
- Help 90 Civic With ZC No Start
- exhaust
- b-16a implant restricted top speed or not?
- Seat belt not going back in?
- Problem one: CEL
- MPFI Conversion Question
- Car doesn't want to start due to the Bosh box
- so my week...and my job are sucking...worse
- need an engine.help
- D15 vs D16 blocks and cranks
- 86 REX.. worth doing anything?
- FLUIDYNE radiator
- b18 wiring questions
- what exaust systems r u runnin
- racing q
- Wanted 90-91 CRX Parts
- coilovers v. lowering springs v. air ride.
- 90 civic fender on Crx?
- need help!
- stripped tranny, need help
- Converting Civic 92-95 Suspension to 94-01 Integra
- Is steering adjustable?
- Momo Seats Installation
- PR4 instead of PM6 for chipping??
- To LSD or No-Slip?
- injector question
- noise reduction help
- What All Do I Need To Pass Inspection?
- stripped lug nut bolt question
- Fix a flat bottle.
- My RPM goes wild on park & neutral.
- How about this for a deal?
- does a 88 crx door fit a 1990 crx?
- bore out 85mm+? on resleeved b20 crx
- b16 throws codes in reverse
- b16 running problems
- Got a new car.....Finally!!
- How long can it last?
- Tie Rod End?? Perhaps?
- can this be replaced?
- 88 Crx cranking problems
- Suspension help!!!
- wiring
- HELP!! 89 Civic Hatch Problems
- Problem starting
- Problem starting
- should i mod my ef hatch or save up for a better base to mod?
- new crx owner
- bushing
- GSR cluster
- holy crap!
- suspension
- just picked up a new hatch...
- RHD Starting problems, Injectors not firing
- Help, Engine is going to blow up!
- Emissions for B16-NOx question
- Newbie with a starting problem
- Eibach Pro-kit/Sportline
- b16a1 question
- Fuel pump location for 4th gen Civics
- Exhaust questions
- Random...not starting??
- need to raise up alittle bit. spring/strut spacers?
- How do you search the archive?
- b16 help in 88crx hf
- Question for you CRX owners!
- I'm kind of confused...
- exhaust
- hmotorsonline.com and b-16a for 91 crx si?
- Vacuum hose diameters
- B16 question
- pics
- lol NOOB ????????????
- ok, that's it!
- Engine ?
- Where can I find DOHC ZC Clutch kits
- squeaky clutch pedal
- CRX Del Sol Electric roof - Help please
- Never buy unless you know the return policy.
- MPFI swap
- Manual trans question.
- Question about ECU????
- Dash swap?
- Help with radiator fan plz
- problem...help
- Body kit or mod?
- Tranny, Axles 93 B18A1 With 97 B18b1? Answer needed ASAP going JunkYard Hurry Thanks
- CRX Si Bumper Compatibility Question
- clutch?
- Window removal
- Clutch kit question.
- Si wiring harness
- Tranny Question????
- Ls V-tech wireing help!!!
- so this is my first post...
- CRX Lowering problem
- Will not go in first.
- can't get the oil pan out, help.
- Higher milage tires
- Car won't start
- not really important
- 1989 honda civic std to LS VTEC
- How to remove hatch struts from an 89 Civic Si?
- crx rear defroster
- Bridgestone or Sumitomo tires?
- get a dohc zc vs. 1stgen b16?
- *help - '88 CRX needs new clutch*
- PCV Valve Hose
- Attention
- for the dpfi to mpfi, can the ex ecu, manifold, and all the other stuff be used for..
- Mugen cai help needed!
