my temp gauge is out?
Old 12-23-2004, 01:24 PM
Mackenzie C
Mackenzie C's Avatar
Default my temp gauge is out?
why would it go out. i swear it was working last time i started it . or is it because its to cold? cuz its real cold.
Old 12-23-2004, 03:50 PM
VPUPPY
VPUPPY's Avatar
temperature sensor possibly or a gauge problem.
Old 12-23-2004, 04:37 PM
Mackenzie C
where the sensor at?
Old 12-23-2004, 10:44 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
The sensor is right next to the ECT sensor on the thermostat housing. The sending sensor is smaller.
Old 12-26-2004, 08:23 AM
Kai
Rotorphile.
Kai's Avatar
Depending on where you live and how your gauge is calibrated, it is possible that it isn't getting warm enough to move. Have you tryed letting it idle up to temperature, maybe about fifteen minutes from a cold start?
Old 12-26-2004, 05:52 PM
Mackenzie C
thats what i did. i started it and left it till the heat was warm. when i start the car the temp gauge goes up but then it just drop back down, he hee.
Old 12-29-2004, 09:45 AM
Mackenzie C
wheres that at?
Old 12-30-2004, 04:58 PM
Mackenzie C
i think i found it (someone told me, he hee) is it the black wire under the dizzy?
Old 12-30-2004, 07:18 PM
VPUPPY
VPUPPY's Avatar
on some hondas, follow your lower radiator hose(the bigger one on the passenger side of the radiator, next to the drain plug) until it hits the housing(should be the same diameter as the upper one). there should be something that looks like brass sensor that is screwed into the housing and has a connector on it. that is the temp sensor.
Old 12-30-2004, 10:17 PM
Mackenzie C
ok, ima check those two things then
