Seat belt not going back in?
Now my seat belt won't go back in all the way, on the top one. This is on a 91 crx si. I took the door panel off. I saw where it's got a blue little cover that appears to be the spring recoil and it says do not remove. I skeeted some wd-40 up between the wheel and the thing, and it helped a little. I've now got it going back in enough where i can leave it buckled and close the door. If i unbuckle it and try to close the door, it hangs down and gets closed in the door. Very irritating. It's going to have to get fixed. Maybe a whole new unit with the belt from a junk yard? Anybody ever had this problem and found a fix? Thanks for any help if so.
Relevance is irrelevant
Mine goes in so slowly.
I've gotten used to feeding it back in whenever I get out, and yes it's a bit annoying, but all the ones I saw at the junk yard were covered in mildew (because all the glass had been shattered or removed).
Not cool.
Not cool.
Honda has a lifetime warranty on the seatbelts, as long as they have not been tampered with. Take it to the dealership and show them, they are supposed to order and replace them at no charge.
