View Full Version : CRX & Pre '92 Civic
- Spherical Upper Control Arm Rod Ends Integra/Civic
- civic si or gsr muffler on b16 crx ???????
- Im Flooded
- New CRZ unveiled at the 2007 TMS
- PG7 Ecu in a 90 crx-si?
- 89 civic obd1 lsvtec
- bilstein sport vs koni sport shock on 2000 accord ??
- crx battery light
- code 14, EACV
- not sure what else i need
- Engine Rotates but I have an issue...
- Just bought a 91 Hatch... any ideas?
- piloted my crx to a new best
- 1990 honda crx HF idle problem
- Recaro seat, question.
- in need of help about a 1989 integra and my 1991 honda civic cx
- Low compression on Cyl 2. Code 1. Bogging. Detailled. Need your opinion.
- blah
- CRX won't start, any ideas?
- Swapping parts
- crx fans watch this...
- ZC troubles
- Doing a tune up. OEM or aftermarket parts?
- 90 Civic wagon, diag plug
- Help! Overheating - fan not running + no hot air
- 1990 civic ex 4 door...bad knocking...help!
- What year is the best CRX or Civic?
- Better brake kit?
- suspension
- civic, which one should i get?
- any point in doing work to a d16
- Can switch out driver's seat with passengers? 85 Civic
- Pop noise from front end
- Any recommendations for OEM parts source?
- idle probs...
- 85 Civic bogs down/hesitates. need advice.
- 90 crx-si vs. 91 crx-si
- Y1 b16 tranny with kaaz lsd
- 86 CRX motor swap help...
- 84 Civic clutch adjustment or replacement question
- 1990 crx ex vtec swap
- i wanna do something different...
- Axle help '91 CRX Si w/ b16
- Shift Linkage 91 Si ?
- Tachometer issue
- Ac Compressor
- Where do these wires go, and why won't my car start?
- 91 Civic DX Sedan
- 93 CRX keys locked INSIDE!
- 1990 civic hatchback wont start
- where is the best place to buy jdm parts specifically gauges and dash parts
- Which tranny for 88 civic w/ZC is best? Si or ZC?
- B16a Wiring in wagovan.. Please help, URGENT!
- mugen header install
- C.A.R.B. compliance
- S1 TRanny oil seals?
- Wires for a 91 Si Civic w/ B16A?
- Need help with 90 crx si
- what axles for b18b swap
- Fuel Delivery Issues
- Ripped/torn axle boots...
- making my own wiring harness
- 91 honda crx clutch problems
- I have fuel, and spark, but the thing wont start...
- Lost my Dad!
- Best place for parts
- my CRX wont start sometimes.
- help with color choices
- upper lower strut bar f/b install
- Where to buy parts for b16a in 90 Civic?
- oil pan drain bolt
- need some help with my exhaust...
- Front End Problem
- Ranting with some questions...
- Cap/Rotor?
- want a DOHC ZC
- clutch in 91 crx si (NEED HELP)!
- HELP!! How do I tell what tranny I have
- rear seat replacements,
- 91 crx conversion
- B16a into DX Wagovan questions?
- "No Smoke"
- Chefboiali
- civic engine oil come out ((((help))))))
- ecu openions for 89 crx
- make zc 91 turbo
- JDM s1/y1 cable tranny help!
- help with my 89 crx
- Brake Light remains on..
- idle help needed PLEASE
- 88 Honda Civic LX Auto Tranny Problems
- Well 90 CRX-Si, Strange rattle
- crx
- any1 got pic of DPFI mainfold and obd0 harness?
- paint for aluminum rims how?
- Can anybody help me out
- a/c system dirty?
- white smoke coming out from muffler
- Valve Cover Installation
- Throttle Body in Roar Mode
- 89 crx I neen openions!
- Basic Tuneup to help problem with 91 Si
- tranny leaks !! any suggestions?
- 89 si wont start after replacing head
- im kinda new on here
- Dual Port DX to ZC Swap Information
- Need Help With A 91 Civic Hatchback Dx
- Backseats help
- Gear Difference?
- Clutch Cable Stretched?
- B16 Vtec problem
- donk having some problems lol 89 si
- CRX Si bugs....
- I' m back
- The Y1 Tranny?
- Help.... Blinker Assembly. 1990 CRX
- Questions about a 91 civic Si i am looking at
- rex stuffed with 20's?
- b 18 b stuffed in crx need vacum diagram
- 1st gen crx SI what can i do > zc??
- A Qiuck ?? I Have
- exhaust smoke after shifts
- My First CRX ^_^
- water leaks
- lug nuts
- Car has funny vibration
- Temp gauge going banannas!!!!!!
- newbie help with 88si swap. ?
- Speedo Cluster Amber Bulbs
- Help! Car about to be gone
- 89 civic hatch B18 What 2 do about my comression?
- car boggs when floored
- crx fuel pump location??
- crx bumper on 91 hatch
- dpi to mpfi conversion
- D15B1 Timing?
- obdo b16 fpr installation
- I Need Help
- Another CRX won't start.
- 89 CRX seat swap in 94-2001 GSR
- Stolen in Phoenix!!!!
- d15b2 sticky throttle? when warm
- car wont start
- Injectors - OEM vs The Rest
- D-series Tranny Question
- ***full D16 Swap****
- Motor Mounts ??
- Code 16 - Engine light and the odd studder
- possible h23 to crx transplant...
- Need a clutch....
- 87 crx si
- just got a crx
- Show the EG6 coupe some love!!!!!!!!!!
- Engine swap
- Camber Kits?
- Muffler
- JDM Sir suspension vs Us Si ?
- 89CRXHF No start
- Kustom Flatz Paint 89civic
- Will a 91 crx lip fit on 91 civic hatch
- idling issues for 92 civic
- 89 civic auto transmission 4th gear ?
- d16 motor for sale
- honda 1986 civic carby tune ???
- car too loud... best way to quiet it down?
- CRX b18a1 to d15b6
- Need new tranny?
- crx wiring question?
- CRX d15 tranny issues
- Another New CRX owner 91 dx long road trip ahead
- Estimated 1/4 Mile Time
- 89 CRX DX with JDM D15B Questions...
- honda civic crx 92 D16A9 not starting
- Please Help!!! CRX electrical problems
- would you....? b18a swap to 91 civic 4dr?
- Oil pressure guage help
- yeah
- Horrible Oil Leak Need Some Expertise
- 99 civic si b16a2 [usdm] into 91 ef
- Thermostat housing ground?? Where?
- Fitting an intercooler on a 90 crx si
- tell me the best color for the cleanest ef hatch
- new crx owner
- engine swapped, now no fuel?
- i just bought a 89 hatchback and what engine should i get pls help me out
- Can someone help with timing marks (belt) ?
- D12B7 Civic DX in a 91 CRX SI
- k20 crx hood problem
- transmission gone
- Suspension!?
- B16A Civic sedan!
- what engine to go in to a 89 crx
- need help with duel injection idle
- Need help converting to Manual trans....
- Hood Hinges
- 1carb versus duel carb
- 4 speed... to buy or not to buy
- need jdm crx front clip
- 88 crx not holding idle
- What Exhaust System for my Turbo B18a?
- newbie here with swap ?
- 72 coupe, goin back to old school
- 1985 CRX Exhaust??
- 90 Crx Si Hub/ wheel stud Question
- B16
- B16 Dizzy question.
- what a deal
- timing question
- 1988 crx si wiring diagram
- Tiger Japanese Auto Parts LTD ?
- 92 civic wont start
- cluch pedal bending/breaking
- b18a vtec or non vtec
- Suspension Question
- MPFI Problem
- B16 Vtec ??
- carfax help pretty Please
- Injectors
- I believe so
- mpfi swap engine flooding!!! HELP!!!
- ZC question
- Engine Building: CRVtec or B18?
- Blown Engine how to rebuilt
- 91 civic oil pressure problem
- turbo time
- 5 speed rebuild
- Start, run, die randomly, plz help
- need help looking for a part...
- after winter?
- covernting a 96 b18b to obd0?
- block swap
- crx hf mini me
- what exhaust?
- help...
- 1990 honda civic Brakes
- d16 turbo need trouble help
- b18b swap 88crx
- Looking for JDM Mugen Crx 88-91 Body kit
- D16A6 Cylinder Head Questions...
- Fuel system ISSUES
- best suspension for 93 civic hatch/h22a swap
- Time for a starter..
- 89 crx clutch
- have a question
- My EE8 CRX :)
- 91 civic wont start
- Faulty Fuel Injectors?
- engine knocking????
- Help!!!
- D16a6 swap to D16A Idle speed issue
