View Full Version : CRX & Pre '92 Civic
- 91 civic dx hatchback stumping me big time
- getting rid of my 90 civic.....
- Need help checking a car...
- Fuel injector problem
- Noob Intro
- bad hesitation, wont start hot.
- Best cams for HP gain for B16a?
- Brake Question
- how to you distinguish between the 88-91 si, dx,etc. transmissions?
- Pics of CRX torn rear crossmember
- really bad idle after head swap!!!
- Sunroof bolts stripped?
- just bought a 91 civic dx hatchback
- 91 civic dx 1.5l
- Tires
- Recommendations?
- distributor problem, please help
- Rear mount ripping out
- Next Mod
- Does anyone know about how to put the window cranks on, and keep them on permanently?
- SiR 1 or SiR 2?????
- Radio won't Go off?!
- Considering Juice
- wiring vtec
- sohc vtec ecu!!!!
- which ecu?
- Check Engine Light, constant flash
- 89 civic DX b16a swap wiring question
- Exhaust Question?
- Couple questions
- ?? About Timing Belt
- Checking the valves...
- Rebuild or ZC
- power windows from a 90 ef8 into 88 crx is it possible?
- Ef squad?
- Anyone know anything about NOS in a CRX?
- 86 DOHC CRX Si
- d16a6
- 88 Civic LX Problem
- 3+ Questions Honda CRX HF
- Hesitation 91 CRX
- OBD0 PR4 Wiring in Si
- Approximate total cost of engine swap?
- ebay mounts and axles?
- whats the cost for a new wheel bearing?
- B18a in a CRX ?
- Low End Power
- '91 CRX battery discharging
- A few Zc questions....
- uberdata ?
- Long block
- Which AEM cold air intake?
- What is this Called?
- Electrical problem?
- Which filter for JDM b16a?
- Popping outta 2nd
- Looking for a front camber kit, 89 Si Hatch
- CV Boots Bands-Special tool?
- 91 CRX si, The REAL Zoom Zoom!...
- new wheels what do you think!!
- Lookie what i did tonight...
- Tein EDFC
- full ITR suspension on a ef, is it possible?
- how do i identify zc motors?
- SPC Adjustable Balljoint Queestion.
- looking to buy a 88-91 civic si shell
- Manual to Power Steering
- 91 SiR pics!!
- stock honda wheels
- Engine Swap Complete Pics
- 91 Civic, locks shifter when in park..Help
- 90-94 LS motor into a 89 Civic hatch
- To Many problems...
- How many quarts of oil?
- Ebay Swap CDs...?
- idle help
- Question About Speed Sensor
- Question about IAT sensor
- Engine Ticking
- Good Buy?
- damn egr
- When I slam the gas the Car runs on 3 cylinders, why is that?
- b16a starter equivalent
- Question about brakes
- ZC vs. B18A
- dx to si help
- taking front wheel off
- what honda?
- Starting and Idling trouble.
- More power
- converting dx to si need help wiring the intake manifold
- vtec to a msd rpm activator switch??
- vtec wired to a pill?
- VTEC turn on Point
- 85 CRX si head swap?
- 88 CRX Si OBD-2 conversion
- Obd1 Zc
- 1/4 mile time let me knoe your thoughts
- Adjusting Fuel Pressure Regulator
- clutch help
- Odd rattle noise?
- For The Love Of God Help My Brakes
- What type oil weight is the best for B16a?
- ok
- Write up about Hasport Sub harness
- Integra parts on an HF
- CRX with B16A header fitment
- Tail Lights
- help please, my 95 civic ex won't start!
- real amber corner lenses?
- ecu help
- so cal mini me swap
- OBD question
- 88 Civic Project
- About to buy motor, need help!
- NEED HELP on 88 civic heater motor relay
- Bleeding the Brakes
- What Can I DO????
- Code 7/ Switched TPS
- My B16a before shots and swap in progress shots...
- Help Locating Main Relay - 90 CRX Si
- Alternator DIY...?
- Need help in Easton Pa area please
- crx b18 swap
- floor mats, what's up...91 CRX ?
- Question about engine swap???
- a/c compressor help
- Where to get a Short Ram Intake
- Crx---> Integra Ecu Swap
- jdm parts?
- problem when drivin
- anyone ever attempt to make a body kit?
- hmm no interior light door buzzer
- Will Tornado in the intake tube increase HP?
- parts
- JRSC installed!
- can I use a cable tranny with a 94-01 b18.
- fuse keeps blowing
- AEM cold air intake for CRX w/b16a
- My B16 powered CRX
- Can you find these at a dealer?
- b18c5 into 91 crx hf
- Intake fitments....
- header gasket??
- Is a k-series motor a smart engine swap for a crx?
- Sri Help
- d16y6 in a Crx?!!!
- Will no muffler hurt gas mileage?
- car won't start
- import help
- windshield replacement cost?
- Chipped ECU
- My cousin needs help
- Alright i need some help...
- help
- what was last year for CRX?
- Car Starting troubles
- engine reaplacement for dummies?...
- how to stop/disconnect annoying door buzzer
- Idles rough & erradicly & other problems...
- decided on an ef
- Extrude Hone Porting
- I'm Back with a dumb question
- Quick Question?
- Replacing the timing belt on my '91 Civic Hatchback DX...
- tranny help
- Idle, shifting, beeping noise HELP plz
- jdm rear seat
- Ebay Coilovers ?????
- B16a Tuning / Timing Problems
- Car drives really Sluggish when I hit the gas
- ready for a ZC swap
- tranny help
- Wierd Shaking
- I Need Help Installing A Ex Gauge Cluster Into 91 Civic Dx
- Pics of my swap finally
- CRX Stock Ride Height
- Gapless Piston rings...
- does anyone have the turbo specialties kit?
- 91 LX Sedan Rear drum Brake Shoes
- questions on a crx flush mount rear spoiler
- I think i have a starter problem!
- Will this stuff fit the D15?
- car codes
- will it fit?
- Don't know what engine code
- 87 crx hood question
- '90ish civic dx hatch...worth it?
- Plastic burning smell when stopped?????
- 2 Round Green Connectors leftover
- what injectors can i use
- f-series in a 88-91 civic hatch dx?
- How much power would I gain?
- K series motor in a CRX???
- JDM on USDM...?
- Feelings on exhaust
- 91 Civic starting/acceleration problem
- My CRX and Swapping...
- Torsion bars???
- What's the next best option for more speed for my 91 CRX?
- Underdrive Pulleys or Cam Gears?
- B16a Bottom End question
- B16a0 = codes 43 & 44 (Engine light lit)
- Right hand drive conversion
- PR3 ECU Pin outs
- vtec problem
- B16 ques
- Question about Oil-Pickup
- Integra dash in CRX?
- abs brakes
- ok
- performance trouble
- Having a serious issue with my motor...
- need help with oil pres. guage
- Hondabond and the valve cover gasket
- gear noise
- new CRX owner
- Exhaust
- Moroso Drag Race Oil Pan
- Help on Clutch upgrade
- whats wrong with my car
- Engine is flooding and bad gas milage
- Exhaust ques...help!
- Ractive brake rotors
- No Hatch?
- Downpipe angle? On CRX
- crx hf re-build kit
- Oil Filter For 91 Civic Si W/B16A1
- typeR or not typeR
- 90 hb civic rear breaks
- which clutch, which tranny
- Converting Automatic to Manual
- potentially buying car
- What are the best Cam Gears for a B16A?
- Any CRX with b16a or turbo racing videos?
- Wanted: 87 crxsi rocker arm shaft
- Engine runs rich HELP!!
- Bad ignition switch?
- Queston for you Rexers
- Anyone have any 90 civic sturts for sale?
- No Hazards Help
- OK need info.
- Front End Conversion for Integra
- Blox Performance??
- Front crossmember compatibility
- Best Compression 4 Pump Gas
- Best Engine/Motor for a Engine Swap
- I didnt know where to put this?
- Why does my car hesitate in low rpm?
- Great Info
