View Full Version : CRX & Pre '92 Civic
- intermittent starting problem with '90 CRX
- Still have a problem with my knock sensor, and Need Help
- engine cranks
- JDM Type R Valve Cover/gasket
- Does anyone have aftermarket parts?
- Spark Plug Issue
- Whats the diffrence between Hi flow cat and test pipe
- Suggestions about performance mods
- In a little jam - help with exhaust and sway bar.
- Car almost/does die when reving?
- LOL, my tire wont come off... quick help anyone?
- Need help, troubleshooing new head unit
- fully built B16A1 turbo in CRX for grabs
- JDM conversion in a 4dr civic
- crappy wired car
- CRX seats F/S in Ny Area
- Low Voltage to Left Low Headlight + Fuses + the like
- distributor question
- Lip Kit for CRX?
- What swap should i do?
- Wiring Problem 95 D-series VTEC into 91 DX Hatch
- how to know if axle is broken
- Hey guys, need help/advice
- Console
- Dual Bend...
- Whats the best swap for a 89 hatch?
- 6 Puck OR Street Strip Disc
- Knock Sensor Problem????
- Need D16A6 Turbo camshaft
- AEM CAM GEARS vs SKUNK 2
- make bumper blinker stay on as running light
- D15B2 to a D16A6
- Problem with TPS
- Engine building, swapping, boosting
- Need help with TPS and knock sensor!!!!!!
- SIR2 Head on a SIR1 Block?
- Shifting problems?
- Waz Up Honda-acura
- Swap without tranny?
- RE:Mechanic To Recommend
- Dohc Zc
- ex door panels?
- 88 rex
- What car does the B16a1 Belong too?
- Engine Knocking
- Does anyone have a B16a Head 4 Sale?
- Gsr Center Console
- brake pads
- whining noise coming from tranny
- Nicest way to remove the hatch struts?
- Sources for fenders and ex. door panels
- how to install an antenna?
- how do you remove vents from the instrument panel without breaking them?
- 91 hatch brakes
- Anyone else have overcooling?
- Lip Spoiler to modify
- Fender questions
- CRX idle problem
- Clutch Question
- 90 Crx si car wont warm up.
- GSR Cluster in 91 CRX?
- question
- Strut Bar
- Master Cyl & Oil Pan
- 1991 civic standard B18 swap question
- Can A 90-93 Teg Bumper Fit EF
- Starter Problem.... (I Think)
- Search but no luck...can Accord Front struts be used on my 91 Hatch?
- problems with my 89 civic
- How do you remove footrest from carpet?
- Vision corners for sale on ebay
- Speedo clip
- What Fits?
- Smells like burnt
- Check out my CRX restoration
- Help, No Heat
- Help a brother out, SiR Questions
- best motor for my 1989 hatchback
- Help
- Dpfi to MPFI b16
- e-brake?
- 92' civic si
- 91 CRX HF - bored out
- you guessed it - another starting problem
- B16 Tranny or B18C1
- How do you remove door panel from seatbelt?
- need help on swap D16z6 into 94 HB
- How do I change the bulb in a projector headlamp?
- gauge question
- Holy Crap! What In Da Hek..............
- Injector help?
- D17a1 camshaft
- Check out my Honda Site
- ZC Swap...
- lambo doors!?
- Weird noise when I brake or pass thru rough road
- intake for 91 civic si w/ b16 swap
- Leaking Charcoal canister
- Wheel/Tire Setup
- is this site a good site to order from jhpusa? any feedback.
- getting a '87 crx hf, going for a ground up build--need suggestions
- 2nd Follow-Up on Start Problem: Problem ID'd
- Annoying squeeking
- one last question, then I'm good...
- 89 CRX HF EGR Valve
- it's a general question!
- Ignitor Help - Please.
- b16 tuneup parts for gsr,si or what??
- Anyone Know Of A Site 4 JDM SIR Tailights ETC
- Yokohama AVS ES or Dunlop SP Sport A2
- Finding horsepower
- Will a 93vx radiater work on 90 hatch w/b16
- Least expensive, fastest Honda?
- zc engine trouble
- Need air intake for 89 crx w/B16 swap
- it didnt start so i started to.....
- crespo?
- Corner lights
- 89 Crx a good buy at $1,250
- 1988 Honda Civic Sedan wont start
- zc valvetrain
- Follow up on start problem
- Timing adjustment
- 88 crx parts for sale.
- car whines
- D15B7 or D16Z6 into an 86 crx
- Sohc Detailed Engine Assembly. Link? Online Manual?
- Lip Spoiler For 91 Hatch
- headers for 91 si w/ b16
- small problem would like a response tonight...
- more speed
- I Need Major HELP!!!
- Cheap headers on ebay, any good?
- Blower fan issues :(
- ef hatch
- Kumho 711's vs Nitto 450's
- 4th Gen. Civic Get together
- For Sale!!!!!!!
- Can't find 95 civic lx wiper arm.
- Clutch for B16a1
- 89 hatch b16 what upgrades now?
- omg DIAF surging idle!!! :madfawk:
- Water Pump Gasket
- where is the thermostat and what does it do?
- Help, rubbing noise when clutch engages
- Stering Wheel
- engine predicamint
- Pros & Cons on GSR HEAD
- "Minor" starter problem
- PWO & PR3 ECU Difference
- Pictures of 91 civic si
- Carb to FI
- Fog Light Wiring Confusion
- Pictures of Ride 91 SI
- Cold Air Intake for '90 Civic
- underheating inside, overheating engine
- Puck vs. Regular
- zc motor
- what is it?
- cheap way to adjust camber on 89 hatch back?
- overheating, clicking noise, wont start
- Oil Resevoir Catch Tank
- Fuse Problem with 91 Si Civic
- Does anyone know how to adjust the freeplay of the clutch so it catches better?
- 85 CRX DX Fuel Injection Conversion
- Tensioner adjustment
- idle question?
- Weird Idle
- Does anyone have a stage 1 clutch or anything better than stock clutch that they want
- Is an S1 tranny good?
- Should I GO OEM or After Market
- need help with camshaft and gear!!
- automatic to manual
- gas pedal has too much play
- Gas light in Ef's
- 90dx w/b16 swap please clear this up..
- throttle position sensor
- spark plug seal?
- mini me or zc swap?
- mini me swap
- Replacing 1990 civic front bumper cover
- heads swap?
- 91 Civic (HB) Injectors
- Just a quick question about 91civic hatch SI for my bro
- Can someone give me some help!!!
- How many MPG did or do the HF's(crx) get?
- h22????
- hf tranny to si tranny (is it worth it)
- Gear oil refill
- 88CRX DX AT want to swap to ZC.
- Help with 91 Civic DX!!
- Will 400lbs slow down a crx si dramatically?
- How is the Kaaz LSD?
- is there eany way this will work???
- Type R motor into EF hatch
- High flow cat or pipe from heaters back.
- Can I buy a LSD and install it in a S1 tranny?
- How much do I torque down the botls on a B16a Head?
- 91 si hesitates/bogs/sputters at low rpms
- Ok, time for new exhaust...recommendations?
- would these crx headlights work on a ef?
- Does anyone have aftermarket headers they want to sell?
- MPFI affects mileage?
- Question about starter
- catback v. axel back !?
- CRX Si RPM idle speed?
- 88 crx si. slow reaction at low rpm
- do ef hatches and crx's hve bad aerodynamics?
- heater problem
- short throw shifter
- My car seems to start sometimes but not others.
- I set the car idle, and then it somehow goes back and get up to a higher rev.
- Rim size confirmation
- something popped in my air ducts, and now...
- 91 hatch dx swap info
- heat problem
- head swap
- Wheel Hop!!!
- Rear brakes
- Rear Seat Removal
- All Motor- No car.......
- Swap Question...
- Setting timing ahead in '85 CRX Si
- FREE - Civic for parts
- will the fender work
- Steering Column???
- 88 crx hf b16 swap
- question on b16 code???
- cleaners
- in knoe...but
- Hard to start after sitting
- Is there Throttle sensor or is it the timing off?
- what's a good set of plugs& wires
- thinking about going lsd
- 91 Civic DX with flickering lights
- b16 wont stay running
- Alternator Trouble In an 89 Civic 4dr LX
- test
- 89 crx si rich at idle!!!
- is this real?
- Exhaust piping.
- short throw
- Stock 1991 CRX DX Hood 4 SALE!!!
- Does anyone know where to get stock parts for a 1991 CRX DX?
- When I let out the clutch and punch it, the car revs, then slowly takes off????
- What is the next best thing for a CRX with lots?
- tranny with swap
- S2000 vs. crx question.
- radiator ?
