View Full Version : CRX & Pre '92 Civic
- What weight oil For B16a S1 Tranny?
- zex- comp camshaft vs. crower camshaft
- B16 Swap Help
- jdm swap passing smog
- Rubber. Haha,he said rubber..
- Door panels,still waiting for answer
- Door vinyl
- What difference will Silicone Bronze Valve GUides make?
- which cv boots?
- help with front suspension replacement
- 91 Civic DX, motor revs up and down at idle
- check out the boys CRX ..what you think???
- camber kits
- swap cost
- What is a good Fuel Pressure?
- GSR head on an LS Block
- 6 Puck or Not?
- d15B vs d16Y8
- clutch cable to hydrolic slave
- Injen Intake or AEM Intake? suggestions
- f22b
- intake help
- crx drivers side window swaps...
- crx drivers side window...
- 88 crx question
- 91 Crx si front lip question
- CRX VTEC Question...
- 1989 Civic LX engine swap plz respond
- Rebuild or swap? what to do...
- 89 crx dx OBD-1 help
- 88 tailight question...
- When the new CRX come out??
- Anyone Local who could help
- ZC/1.6i-16 Swap Need Help
- crx seats
- Dyno GSR Setups
- Looking To Buy Crx Shell (88-91)!!!!!
- More GSR Questions
- p28 swap question
- interior question
- CRX Motor Mount Question
- EF Door panels
- Parts swapping
- Why doesnt my 90 CRX turn on??? PLEASE HELP
- Crx intake question
- Traction problem
- 1990 Honda Civic
- CRX Pillar Bar question!!!!
- D15B7 Head on D15B2 Block
- need knowlege in weight reducting a 89 civic hatchback si
- Does Anyone Have a Similar Setup?
- Can you buy a lightened flywheel at Autozone or any local pats store?
- CEL is giving me a weird code!
- Need engine source, ZC 1.6i-16, or B16
- I need help with a b16a into an 89 civic hatch
- just purchase 88 civic hatchback 127k
- D15b
- b18c1 in my crx?
- JDM Front end
- What causes negative camber, other than lowering you car.
- CRX stock ride height
- Taillights
- Engine Swap Questions
- CRX Aftermarket Racing Seats?
- need si hubs
- Check Engine - 02 Sensor Question
- Engine Miss/Sputtering/Stalling Out/Hard To Start
- Help
- dead 87 si
- dumb question, center caps
- swap question
- 90 crx 1.5 everything stock
- STOLEN 87DX-- Vancouver, BC
- rear strut bar problem
- HF Brake upgrade
- help quick
- Noise in front end
- Disc brake swap question,
- Took some pics of the CRX today..17 pics
- 1991 CRX Si Headlight ans Fender
- zc engine in canada
- Steering
- CRX front lip
- B16 check engine light
- No start & Idle issues
- Idle up on its own & no start question
- ls/b16 swap doesnt like to start in the mornings
- What is symtom of bad Map Sensor
- Paint And Color Schems
- Please welcome a new CRX and Pre '92 Civic Moderator
- 4 speed manual spindle question?
- b16a type r cams
- wiring help
- How would it fit?
- how to/ reason for removing 2nd butterflies in gsr intake manifold.....
- Dead Horse
- My dash, my lovley little dash
- b18 swap help
- What is the Most you can Safely Bore out a B18B on Stock Sleeves?
- new here
- Won't start- not the usual symptoms
- cluster help
- How vtec works... I think I get it now...
- Wideband O2 vs Regular O2
- 1990 Civic Wheel Cylinder Help Needed!!!
- rough idle/vibrations?
- Just had an overhaul and now...
- Popping the top
- Notorius seatbelt issue-pls read me!
- NOX level too high...90' std hatch!!
- 91 CRX Body kits??
- this is my ride
- B16a1 in a 89 si hatch.. bogging problem
- CRX hF weight advantage
- car wont start unless i crank it 5,6 times
- Will it have enough fuel???
- Code 41: Primary Oxygen Sensor Heater (what do I do?)
- swap help
- wierd smoke problem
- 1984 crx help needed
- ef8 crx wants to put ef2 one piece on?
- need some suspension help with my crx
- ef8 foglights?
- D16A6 ecu, manifold, etc with a D15 block
- Anyone done crx d16a6 w/ d16y8 vtec head?
- Mitsubishi Eclipse Spyder GT
- 88-91' Wagovan/Shuttle...
- Electrical Prob...90' std Hatch
- getting headache!!need help on engine light..
- Does any know Matthew Auvingne From Canada
- H23A1 into a CRX
- Where can I get a OBD0 B16a Knock Sensor
- 92-93 gsr sway bar??
- B-series swap question
- wtb: crx driverside window
- Where can I buy an LSD for my Trans
- g tech ss, Good product?
- LS block for sale
- Any1 wanna trade an automatic for a manual
- vtec solinoid
- 91 crx z6 swap need advice
- Interchangable suspensio for CRX
- headlight problem
- Hydro conversion?
- Speedometer quit working
- what is this??? 1988 crx dx block.
- 91 crx x6 swap help
- Weird Question
- 91 CRX HF clutch issues/inquiries.
- Newb here with a 91 ef9 hatch...
- Squeaking speedo?
- tranny ?
- Finally got the pictures from my accident!
- 1986 Honda Civic Si fuel injected Dead on road
- Which is Better, a SST Eprom or Amtel Eprom?
- How many miles for break in?
- ecu problems....wont turn off
- 87 CRX help!!!
- honda and acura racing break systems
- b16a2 prob where do the main bairing caps go
- B16B Piston Question
- New Jersey Meets Honda Crx
- 00 si rims on ef
- bracing my crx
- hello new to this but I need help
- 91 civic sedan engine swap list
- First time Honda owner.
- What next?
- 1986 crx body kit
- 90 Civic HB Si Alternator Question
- Project Crx need help
- My 85CRX is shaking in 4th.. What do I do?
- engine weights anyone?
- Can someone help?
- Suspention ???
- Which Axles?
- 92 civic block swapped for a 88 crx block??
- my new ef project(56k take a nap)
- CRX Seat belts don`t recoil!
- 88-91 crx front and rear lip kit on similar hatch?
- Anybody have this high flow cat?
- Apexi Vafc Question
- 88 crx rear interior panels
- no ac
- New 2007 CRX!
- JDM D15B swap
- 88 Crx Si Coilovers - Good or Bad?
- Throttle body and intake manifold question
- b18a into 91 civic
- unsolvable brake problem need help
- 1.5 and 1.6 compatability
- Re did my battery cables and grounds.
- starter question
- turbo install
- keeping me up at night
- MSD 6a, blaster ss coil, and lightened flywheel(to buy or not)
- Backup lights problem?
- where can i get a rebuild kit for a D16?
- What do you do If you can't find a Cylinder Hone with 400 Grit Stones?
- So, My Friend Never Honed his cylinders!
- Alternator & Waterpump bolt - HELP!!!
- 4dr lovin
- Whats next???
- yeh lotsa wirein problems:p
- car wont go above 3500rpm
- 91 crx si clutch and flywheel question.
- car runs rough after installing dsm injectors
- Question about transmissions....
- Squeak, squeek
- will these injectors work for my set up??
- Shock Help!
- Crx cat question
- 89 CRX Hypothetical Swap Question
- motor swaps
- best motor for a 90 crx
- tps signal wire
- ARP Headbolt install
- What can be done now?
- Aluminum rim cracked.... Can it be repaired ?
- Vtec problem
- Dash Harness
- Do I need bigger Injectors now?
- Exhaust question
- Does anyone have sound clips of exhaust systems?
- What do I do to the car once I put it back together?
- What else do I have to do to the car while I got it apart?
- Type R Final Drive? How good are they?
- Phantom Grip LSD for my S1 Tranny?
- broken shock
- NO high beams?
- Shifter on CRX new but very stiff please help
- I installed Car Battery on CRX Backwards car not start HELP PLEASE!!!
- tech question about injectors
- Why the Hell do my new Tociko Shocks do this?
- SO My Timing Belt Slipped off...How Bad is This?
- trunk problem?
- Need A Power Steering Pump!! Asap!
- Car Continuously Revs while in gear how to fix?
- Turbo in a 91 crx si questions.
- WTB: *DESPERATE* Steering wheel for 87 CRX
- jdm single cam vtec zc weird idle...
- transmission fluid??
- Shift light question
- Autometer d-pic
- your opinion on what i should purchase
- Front end alignment problem?
- How much does an 86 Si Weigh...
- crx dohc zc head shave
- 87 crx si
- b series transmission experts
