vtec solinoid
Old Jan 25, 2006 | 05:58 PM
cokesbody's Avatar
cokesbody
Default vtec solinoid
does anyone know how too wire a the vtec on d16xz6 and could antone tell me would it be worth it to cam it up
Old Jan 25, 2006 | 07:59 PM
Exempt's Avatar
Exempt
2 tone Rex
Which ECU? Which car? OBD0 or OBD1? OBD0 ECU will need an RPM activated switch... The OBD1 P28 ECU will need 2 wires, one for VTEC activation, the other for the VTEC Pressure switch...
P28 pinout:
http://www.hondaswap.com/forums/inde...ype=post&id=32
Descriptions:
http://www.hondaswap.com/forums/inde...howtopic=29360
Old Jan 25, 2006 | 09:01 PM
cokesbody's Avatar
cokesbody
i bought a harness adaptor for the p6 too the p28 ecu its a 91 crx si i took out the resitor box for the injectors and i used the z6's injectors not the a6's I also soderd and spliced the distributor wires and lengthen the reverse light wires. Im just having problems with the mapsensor and vtec wires then hopefull i can start it.
