Type R Final Drive? How good are they?
Old 12-20-2005, 04:18 PM
RedlineBoyzCRX
EG6
RedlineBoyzCRX's Avatar
Default Type R Final Drive? How good are they?
Well, I was thinking of how to get up and go in my car a lil faster. I would like to put a Phantom Grip LSD in my car, but also I want the Type-R Final drive in my car, I hear that they are really good and get the car up quick. Has anyone installed one themselves? How much better does it make the car get up and go? What else could I do to the tranny to make it rock solid and make it better?
Old 12-20-2005, 05:22 PM
ED9man
driver
ED9man's Avatar
Doesn't work in your trans I'm pretty sure. The lowest you can get is the 4.4.
I'd save up for a Quaife and go without a new, expensive FD for now.
Old 12-20-2005, 05:47 PM
shivers
Moderator Alumni
shivers's Avatar
In order to use an ITR FD, you'll need a GSR or ITR differential. Another option is to get an aftermarket unit (Quaife) for GSR/ITR and use the FD with it.
2005 s2000
Old 12-23-2005, 04:10 PM
Kai
Rotorphile.
Kai's Avatar
If you're talking about the Japanese 4.7 final, you don't want that anyway. It will drive you nuts on the highway.
Old 12-23-2005, 06:34 PM
ED9man
driver
ED9man's Avatar
I wouldn't mind a couple hundred rpms over my 4.4 :dunno:
Old 12-23-2005, 08:15 PM
Kai
Rotorphile.
Kai's Avatar
Well, I'm used to driving a .697 5th through a 4.10 rear end... 3k@80mph.
My busted ass Stealth (no 5th gear) pulls around 4k at the same 80mph.
When I rode in my buddy's EG/B18C, I kept yelling Shift! Shift! Because 4k was rediculous to be cruising in a healthy car, in 5th, at normal highway speeds. A 4.7 final would only make that worse, along with decreasing gas milage and engine life.
Old 12-23-2005, 08:23 PM
ED9man
driver
ED9man's Avatar
But the acceleration!
B series love to rev, and I wouldn't worry too much about mileage in a sub 2.0 N/A engine.
Old 12-23-2005, 09:51 PM
Kai
Rotorphile.
Kai's Avatar
For now, but wait until they get into the 150k-ish milage range after being raped. They will puke smoke. It's a result of the accelerated wear any engine incurs from excessive high revs.
Sub 2.0's should be able to make 32+ MPG. If they don't, you have problems.
Old 12-24-2005, 11:00 AM
ED9man
driver
ED9man's Avatar
You think I'll get 150k out of it? That's not bad at all. It's got like 50k now and it doesn't burn a drop and I drive it really hard all the time.
I'll just get a new longblock for $600 and slap it in there. :dunno:
I get like 27 maybe?
Old 12-27-2005, 06:58 PM
EQMD EF8
EQMD EF8's Avatar
I thought I had a 4.4 final in my b16 swap. I got a JDM S1 so it should have one, but when I got my car running a few weeks ago I noticed that at 65mph I'm at 4k and it's ridiculos(sp?). Some people I talked to said it's a fairly common mod in Japan to put the ITR final in a tranny so it might have one. If it doesn't I could only imagine what one would do. Oh yea, I'm running 205/45/16 tires.
