which cv boots?
Old Feb 20, 2006 | 06:14 PM
xpman's Avatar
xpman
Default which cv boots?
I need to replace the cv boots on my ride. I'm running into the same problem I always do when ordering parts for it. It's got a '92 JDM b16a in it. The suspension is mostly CRX but the knuckle is Integra (big brakes). Do I order cv boots for the 1.5L or the 1.6L or would they the same?? I'm assuming the half shaft is CRX?!
Old Feb 21, 2006 | 07:37 AM
Tankard's Avatar
Tankard
I've always simply gone to the local auto parts store and got mine. Of course, you tell them what kind of a car it's for and they'll get you the right one. Edit: Oh, i just saw where you were wondering which car to get them for because you've got different axles. Can't help you out there.
Old Feb 21, 2006 | 02:18 PM
xpman's Avatar
xpman
Does anyone know what axle is typically used in the CRX/b16a combo?
Old Feb 22, 2006 | 10:01 AM
xpman's Avatar
xpman
Anyone??
Old Feb 24, 2006 | 12:49 AM
Kai's Avatar
Kai
Rotorphile.
It depends which axles you have. Most likely you will need boots to match a 90-93 Integra.
Old Feb 24, 2006 | 01:15 AM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
I had to buy 90 integra w/ ABS axles for them to fit into my intermediate shaft. I have the s1 transmission(but no idea on the intermediate shaft, which determines the axle u must buy). Either way it will be either 90-93 integra w/ or w/o ABS.
Old Feb 24, 2006 | 01:18 AM
Kai's Avatar
Kai
Rotorphile.
He's looking for boots, not axles. The 90-93 Integra boots are the same, ABS or not. ABS axles differ only in the gear ring attached to them for the ABS sensor pickup.
Old Feb 24, 2006 | 01:27 AM
xpman's Avatar
xpman
I was told in another thread that "b-series is b-series is b-series". I absolutely need boots but once I yank out the axle and clean out the joint I need to be ready to buy the whole axle.
At this point, I'm pretty sure I need the Teg components but I'm not sure which axles are interchangeable. Could a '94 axle replace a '92? Even if I can find a '92 locally, it's gonna be from a 1.7L (the GSR I think) because the 1.6L wasn't available for the domestic Integras.
Old Feb 24, 2006 | 04:55 PM
xpman's Avatar
xpman
By the way, is there a part # on the axle? That might make my life a whole lot easier!
Old Feb 25, 2006 | 10:30 PM
Kai's Avatar
Kai
Rotorphile.
No. Axles come in different variations based on body width.
B17A1 (GS-R) and B18A1 (RS/LS/GS) axles are identical. The halfshaft is different (shorter) for the automatic RS/LS/GS.
