where can i get a rebuild kit for a D16?
i am wanting to rebuild a 90 Crx si motor that i have just laying around.... figured you guys (and girls) would have some idea on where the best place is to buy a complete kit... any help will be appreciated.
Sharkbait OOHAHA!
Your local autoparts store
What are you looking to replace? A rebuild kit should include new gaskets (head, oil pan, oil pump, water pump, etc.), valve seals, crankshaft bearings, rod bearings, crank seals, and I think that's about it. If you don't know the mileage and wear on the motor then maybe you should get a rebuilt crankshaft and piston rings, plus have the head inspected for worn camshafts and valves.
http://www.rpmrons.com/Hondakits.html found that one in like 3 minutes of searching on google. Just search for engine rebuild kits. The link site has kits with pistons and rings.
http://www.rpmrons.com/Hondakits1.html are kits from the same guy in Utah, but made by Top Line(manufactures engine kits). They have differenet packages that come with different components.
ebay definitely has cheap rebuild kits if your not looking to spend a lot..
also www.importperformanceparts.net has a shat load of parts and rebuild kits.
EDIT: that site is good as well.^
Originally Posted by 89crxinprogress
how about these guys... http://www.performance-auto-parts.co...kits-honda.php
