D15b
Old Feb 11, 2006 | 12:28 PM
H23A1's Avatar
H23A1
Default D15b
I have a D15B 3 stage Vtec enigine in my crx but the ecu in the crx isnt helping me what so ever i think the one in it know is pm6 or pm8 maybe some one here knows which ecu goes with the d15b to get the vtec working
Old Feb 11, 2006 | 12:46 PM
jlicrx's Avatar
jlicrx
the ECU for the engine is P08 - may be hard to find since it is JDM - a P28 from 92-95 Civic EX will work - both of those are OBD1 ECUs - if you have a PM6, you must be running OBD0 and in order to use the VTEC ECU you would need to convert to OBD1 - or, you could rig up a rpm switch to control the VTEC with the OBD0 ECU
Old Feb 11, 2006 | 01:52 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
Or as I say all the time, you can run the PM6 with turboedit and either do the mod to the ecu for vtec activation or a rpm switch.
Old Feb 11, 2006 | 04:55 PM
Exempt's Avatar
Exempt
2 tone Rex
How do u know its the 3 stage VTEC version? The 92-95s arent 3 stage... Does it have 2 VTEC solenoids? If it is indeed the 3 stage, then you will need the proper ECU which would be OBD2, otherwise you will not have 3 stages of VTEC... The P08 is the OBD1 version for regular VTEC...
I looked it up and found that the ECU is a: 37820-P2J-003 (manual) or 37820-p2j-j61 (mulitmatic)... Good luck with the OBD2 conversion tho...
You can probably run it OBD1 with a P08 or P28, but you wont have 3 stage VTEC...
For a write up on the regular 2 stage D15B VTEC into a CRX look here:
http://www.efsource.net/D15BHT/D15BVTECSwap.html
Old Feb 11, 2006 | 09:30 PM
H23A1's Avatar
H23A1
yes it does have 2 vetc solenoids. Any one have an extra ecu that they want to get rid of?
Old Feb 11, 2006 | 09:48 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
You will also need a wiring harness or modify your own.
Old Feb 12, 2006 | 12:52 AM
Honda951's Avatar
Honda951
Na Dog ALL you need is a Pr3 and then you wont have to convert over cause your odb0 just get a Pr3 and ull be able to pop vtec since your clear plug man and it will be kool or if you wanna go a cheaper route get a tachometer and run them to the shift light so v tec will pop when the shift lite come on...... good luck man.......
Old Feb 12, 2006 | 11:13 AM
Exempt's Avatar
Exempt
2 tone Rex
Stop giving out wrong information... The PR3 wont work because it will throw a CEL because it will be looking for a knock sensor and a secondary o2 sensor which the SOHC VTECs do not have...
Only 4 posts, misleading information, apparent over usage of ebonics in his posts...
And ofcourse this:
Biography:
FuCk YoU hAtErS
fUcK yOu
Interests:
RaCiNg, StReeT rAciNg
Occupation:
DoNt RaCing
I sense a troll in our midsts...
Old Feb 13, 2006 | 12:20 AM
H23A1's Avatar
H23A1
im thinking of just swaping a d16y8 into it
Old Feb 13, 2006 | 06:23 PM
H23A1's Avatar
H23A1
any one from around the bay area that has a p08 ecu that they want to sell
