Will it have enough fuel???
ok im planning a minime swap on my d16a6 and im just going to use a rpm switch to activate the vtec, but i want to know if when the vtec kicks in the computer will see LEAN!!! from the O2 sensor and proceed to richen up the mixture so that my vtec will actually be effective instead of just leaning out my mixture with the extra intake air made by the cam????
Boo Boo Kitty F*#k
Your setup will not work properly because you dont have the right timing and fuel maps. Your setup will work but you will not have the correct fuel and timing so hp will be down. You can either get the vtec wiring harness and ecu or tune your current ecu with turboedit and drop in the correct maps.
Just do it right the first time, you will save yourself a hella hastle. Just get the RIght Wiring harness, get the right ECU. And do it that way. Even if your tight on money, it is better to save up and do it right than dick around and blow it up.
