View Full Version : CRX & Pre '92 Civic
- Intake manifold (89 Civic 1.5 liter)
- hi ppls!!!!
- new seats
- Crx B16A throttle problem HELP!!!!!!!!
- EGR Valve
- Thermo Gauge
- b16a compatable?
- What's better for gas mileage DPI or MPI
- tachometer needed!
- Warning Lights.
- crx body specs?
- what shocks should i get for my '85 si?
- dead civic
- 90 Civic DX...stiff pedal...no pickup??
- code 16... Fuel Injectors
- Where can you get a helm manual? anyone have one?
- radiator question on a 91 crx
- Civic Rear Disc Question
- ROTAS NEWEST GAB Wheels!!!
- How many 194 size bulbs in Gauge ?
- need help ASAP
- Gauge Problems
- Obd ???
- new center consol
- 2004 Car Planz
- Need info on axles
- Help with suspension
- alternator still not sending charge..
- sideskirts
- OBD Location
- Automatic Tranny
- as long as im swapping engines, what else should i do?
- 88,89,90-91 starters the same?
- clutch installation
- parts for jdm b16a
- I know it's been covered. But I have a question.
- damnit i killed the rex now it wont start
- b series strutbars
- suspension trouble?
- Some pics of the crx
- 91 crx rear speaker size?
- pulley+belt question
- Name the problem, vid clip w/sound inside need help
- acura gs rims
- Suspension???????????
- What fuel injector cleaner to use???
- im new with a 91 civic hatch
- CRX D16Z6 swap
- Buying engines
- Painting trim, mirrors etc.
- tranny
- Car Shutting Off - ECU Code 16
- Body kit question
- Dyno'd teh crx... pretyt impressive for a honda!
- gas and water temp gauges help!
- Oil Light...weird...help?, Won't go off...help!
- Selling Civic SI rims, anyone interested?
- How much can I spray??????
- will 88-89 integra clutch fit 88 CRX?
- My Women's Crx
- My Crx has no spark
- teg strutbar?
- Lock Cover
- rotor size
- MPFI: How much hp will be gained?
- wtb: i need oem crx bumper lights in good condition
- Gas tank lever help
- alternator changed and still not charging.? suggestions?
- What Tool(s) Do I Need???
- question about door handles
- costom Intake
- b16 rex question
- Crx Sale
- CRX Question?
- Power Mirrors?
- B16 Crx?
- WTB: 88-91 CRX Passanger Side Fender
- wheels
- crank
- what kind of CRX do I have?
- SOHC Vtec question
- would it be hard to find a stock suspension?
- Ecu
- Other seats
- driverside 91 hatch fender
- Need some help guys...
- Camber Kit
- Swaping motor
- Wiring Help Needed!!!
- ZC tranny and half-shaft questions!
- New CRX(to me)..little more work, and shell be road ready...
- Favor...VIN Check
- Question...
- Ls/Vtec Questons
- 90 Civic Hatch
- Carbon Fiber hood
- 91 crx hf putting when idle... suggestions?
- fuel problem??
- fuel cutoff problem?
- Power Steering Installation
- project, nonvtec/nonturbo d16
- 87 REX motor swap, need help
- GSR in 90Civic DX?
- b16 and california smog
- z3 fender disaster
- 91 crx alternator
- HELP: broken fuel rail stud
- Instument Cluster Light Bulbs?
- Best cams for a D16A6 N/A
- How much can it handle?
- looking for wheels 4x120
- just got last night
- who has an Apex'i VAFC??
- how to change c.v. joint?
- brake booster upgrade
- Ride Control - Bang For Your Buck?
- alternator question...
- (JDM) D15B Help
- what coil do i need to use now for my ZC (MSD stolen)
- engine taking longer to start.. any clue?
- is this possible on a 4cylinder engine.
- fs: parting out 1985 Honda Civic SI
- oil help!
- Cigarette Lighter Wiring
- need a cat back
- CRX engine swap
- Help!!! Car Just Died!!!
- zc parts
- Seat belt indicator
- Suspension? Camber kit? Need help!
- turbocharger help
- Would this head fit on a 91 crx hf d15b6 block?
- b18a wiring into an EF
- alarm wiring help needed
- Civic-Integra swaps
- 92-95 Civic Front End Conversion
- Supra style top conversion on a crx......
- my new toy(project)
- racing module
- Talk me out of it (UPDATE)
- I Need The Speed
- National winning 1990 Honda Civic SI
- ECU Code 20
- I need swap of 92-95 sohc vtec into a 89 crx hf
- My new shifter
- 91-93 teg headlights
- 88 crx si lighting problem
- Surging?
- Ignition problems
- Photo reflectant paint
- 1990 Civic oil, water depletion
- intrument panel light
- OEM Exhaust
- Boot question....
- hood stuck
- vin search
- squeeky brakes help
- Header Question
- engine swap question
- Engine shuts off while driving
- brake question...
- need a civic
- problems, problems and more problems!
- crx problem....
- what size pipe would you guys recommend putting on my car for exhaust system?
- need exhaust pics
- B16 swap
- Need DOHC ZC "Transmission only" - FL.
- Is this vibrating normal?
- how to rewire dx for b18
- weird vibration from the front end
- Planning Engine Swap need Advice
- Need 1/4 Mile Estimate (can win membership)
- Q about cheap suspension parts
- Civic DX 99
- Talk me out of it
- car bogs at wot.
- CRX vs. Si differences?
- noob ?
- Suspension questions
- is it worth it to buy 1991 crx si for 2200?
- Air Intake Question?? Squeal??
- parting out 91 civic hatch..
- opinions on these aftermarket rear lower control arms
- light mod, Carb swap
- '88 civic carb to FI conversion ?
- Cupholders
- clunking noise
- b18a1
- ’91 CRX Si swap question
- '89 CRX wheel sizes and junkyard wheels
- Parting out 90 4 door integra GS red 5speed
- Temperature Sensor
- b16a swap starting problems
- 90 CRX \ B18 injector prob.
- Calling all users with lowered cars or catbacks with pictures of them!
- power window kit for crx?
- 88-91 custom tail lights
- center consol
- hf ecu?
- B16 swap ECU question?
- Heater Core....
- Hi....newbie here!
- 91 Civic oil drain helicoil?
- Newb with pix
- pics of 2nd gen crx's with dual tipped mufflers
- Updated Progress on my CRX :D
- 91 civic dual to multipoint wiring questions
- honda to acura swap
- Code 43 after LS swap
- GSR crankshaft in ls/vtec setup?
- is this car worth the trouble?
- First Engine Pull!
- My CRX Project!!!!
- BLOWER doesnt blow
- Brakes? Something Else?
- PDA controller
- gotta love the o2 sensor questions..
- my new beater.
- Need help installing stereo
- Mini-me ECU questions
- some hondas have two wheels?
- idle
- operation BLOW UP carb honda block
- Needed! 91 Crx Hood And Fenders!
- Carbon Fiber Sunroof Plug Kit for 88-91 CRX
- Beware of Midas!
- o2 sensor on b18a swap
- Unknown Wire
- saying hi
- big time tranny problem?
- B18A1 into 88 Hatch Dx will I be happy?
- tach install
- universal muffler preference
- idle problem..etc..
- sensor question
- New to HAN
- b18a mount bracket
- where did you get your crx?
- maryland inspection
- vacuum line?
- 91 Honda Civic Seat Belt Light on Dashboard!! HELP
- corner lights
- b16a swap in 88 hf
- Need crx experts......
- Started Playing with my Rex again
- 91 LS engine
- radiator fitment?
- Radiator troubles
