- What year and which CRX had rear disk brake?
- What does CRX..........
- smoked and proven!
- 90 LX idle problems
- mini me?
- DPFI-MPFI - No Reverse Lights!
- Wheel Line
- TPS problem?
- Motor swap options...V6?
- problem with halo projector wiring
- I need pics of a stock down pipe 1.6,1.5
- Halo projector lamp hookup problem
- what DOHC fits in an 86 CRX 1st gen????
- rear mount turbo
- Hesitation?
- civic code 20
- Oxygen sensors
- Just saying thanks!
- Buying
- Some I Be Worry About The .....
- check this one out
- Another "lowering" question.....
- Engine
- b18
- uhh what to say !?!
- My "new" Crx
- install power locks on 1990 honda civic
- Brakes fixed, pedal still like mush
- what computer is better
- 91 civic horn location
- power steering
- Sanding and bondo
- Fuel pump relay question.
- Turbo or Mini Me Swap???
- Lug Nut Size question
- Speedometer?
- power loss
- Exhaust pics for CRX
- need some quick help with ym car....
- Turbo PSI
- Old school...
- what do ya think?
- d15b2 valve adjustment
- compression
- rear disc swap
- Better MC?
- anybody here live in tenessee?
- ? for the smart guys
- CRX engine swap HELP!!
- 91 Civic hesitates on starting
- Motor Mount ??
- Punched it to pass and it slowed down?
- sudden power loss
- Cheap Complete Turbo Kit
- D16A6 block with sir head ? does it fit?
- EW4 Tranny
- timing help
- sorry
- is a gap in exhaust bad?
- B18c swap
- Steering Wheel
- Ls crx
- Brakes Question
- Zc vs b18
- How to you clean the inside of a tranny?
- Which Transmission?
- Got the motor in!
- 1988 CRX CLUSTER question..NEED Answer ASAP
- syncro grind
- does anyone have patience to talk to me about my 91HF CRX???
- Fuel Injector for ZC 1st Gen
- Question I need answered fast!!!
- MSD distributer cap and Blaster coil SS
- Vacuum Diagram D16A1
- need help with crx ls swap
- b16a does anyone know what these sensors do!!!!!
- Shops that do swaps in Georgia?
- help with LED wiring
- A Different Exhaust Question...
- Turbo D Series
- close me
- b16a engine code locations
- EF station wagon????
- need place racing
- Wheels/Tire size
- 1990 Honda Civic Lx 1.5 Upgrade?
- 94+ GSR Radiator in a CRX
- 4 door\hatch questions
- cluster question
- B16a bottom end question
- Swap For My Crx!
- rattling exhaust, yet another
- 91 Civic Lx Chipability? (newb)
- MSD Ignition question
- Hottest Mazda, 1993 Mazda RX-7
- Which oil for b16a1?
- Check Engine Light
- New here
- Show
- 2007 CRX its Back!!!!!!!!!!!!!!!
- did you know...
- Will a v6 Mustang beat a CRX Si?
- tire/wheel question
- Gas Leak Help!!!
- Will a B16a2 Head gasket fit a B16a1?
- 91 Crx Front Bumper removal
- Honda CRX Manuals if anyone needs them!
- 4th gen Civic Info
- Crx Usdm 5lug Conversion
- Leaky CRX hatch
- fender braces?
- passive rear steering
- ok...
- crx trouble(help!!!)
- CRX problem(please HELP!!!)
- Bet yopu havent seen one of these in a while...
- For the true CRX Weight Freaks! *New Product*
- need help on charing a/c in 89 civic h/b dx
- Power window install w/ SPAL window kit
- Clutch problem?
- 91 civic awd wagon
- 86 Civic HB and 88 Integra Head?
- Bumper lens
- dohc zc
- D15B2 to Z6 Head/Y8 mani/B18 TB Wiring??
- idle ?
- obd0 => obd1
- 2nd Gen CRX Hatch Trim?
- Exhasut question those who know....
- v/c studs stripped need help
- Need some pointers on removing the AC!
- CRX Removal Questions
- attention 89 civic owners
- Hopefully will this work?
- 90-91 Km/h gauge faces
- which cold air intake for CRX w/B16a
- Removing a B16a Head and putting it back on a B16a Block
- 90 Civic Sedan suspension question
- Fuel Pump Problems????
- old prelude motor
- 94 Civic VX??
- What T/B to use on a Y8 intake mani?
- Where to get Performance parts for 86 CRX SI
- Tommorow is the big day
- Compatible parts of D15B7 into a D15B2/Z6
- Project: Civic Si
- B16 In 89 Si vacuum diagrams
- Some questions what should......
- iac valve location
- acura legend brakes on a rex?
- What would be the best next step for my B16a?
- instrument cluster swap
- Will 99 Civic SI wheels fit 1986 CRX
- Z6 mini me swap in an 89 CRX
- Need help with tranny.
- Is my tranny still good?
- ZC/Si Hybrid transmission
- Need a factory service repair manual
- How do u lower an 86 CRX SI front end?????
- Los Angeles County Raceway LACR
- what Altinator for 91 civic w/ b16
- loss of power
- speedometer problem
- My fun spin video from 4/3/2005 event at Ripken - 1991 Civic Si
- b 18 swap help
- help new 91 hb driver
- Best engine?
- re: si and gsr killer ha
- B18 swap into 2nd gen civic HB Question??
- loss of power and exhaust noise???
- 90 Honda Civic HB $300
- 88-91 zc for 850+shipping
- Removing Cluster To Install gauges ??
- need help on distributor and timing belt
- Clutch Pedal Very hard to step on?
- New four door owner here...
- Mugen valve cover?
- I Hate Me Car Help!
- vafc hook up
- rear main seal
- tranny leak!
- Ecu code question
- 4 all u jdm lovers
- Help with my H22 in my 87CRX....PLEASE
- I want a H22 in a CRX 87
- any southern WI 4th geners?
- Best Gas
- Tip on getting my Neuspeed Strut bar?
- GSR and Si Killer
- CRX SWAP GSR Motor Question
- Crx not starting!?
- ZC Oil Pump
- 1988 Civic -- HELP, HELP!
- MPFI Swap
- 88-91 CRX / Civic Automatic Set Up
- 87 Crx 500$?
- b16 head knocking
- B16a?
- where can i find cheap body kits
- Does anyone have???????
- What's it worth (88 Si)?
- 90-91 teg parts on 91 civic hatch.
- 1980 civic clutch
- how do you lighten the stock flywheel
- z6 rings/rod bearings
- crank swap possibilities???
- weapon R?
- Big Problem need help quick
- motor mounts
- 1990 Civic DX starting problem
- B16a Shift point
- Bumper signal lights
- Stripping out a 92 Integra GSR
- Fluid leaks
- how much would a 95 vx motor be?
- help replacing drive axle 1990 crx
- has anyone...
- Which one should I........
- How much does a CRX weigh with a B16a?
- My new 1987 Civic Si-Check it out
- gas milage!!!! WTF is Bush Doing?
- Faster than a Vtec?
- R-63 paint
- Best Motor for a CRX LS VTEC? ZC? GSR? B16? TYPE R? B20?
- Carbon Fiber Hoods
- Si Rims
- CTR,ITR or Aftermarket Cams 4 ........
- YS1,S1 & Y1 Tranny,How Can You.......
- Will my CTR cams fit in my B16a JDM 92-97
- What Auto tranny do i use to swap B20B in CRX
- Turbo or SuperCharger or None??????
- web site ?
- How many more mods can I go?????
- Will my ECU from my B16a (88-91 JDM) work on my B16a 92-97 JDM?
- B16a (JDM 92 - 97) tranny & B16a (JDM 88 - 91) BIG QUESTION
- what to do?
- Found out BustedHB
- Can anyone recommend a mechanic in .....
- hf ecu
- 91 civic trany+b16
- is it better to do a mpfi swap on my current motor or do all the wiring when i get..
- B16a (Civic Si-R II) TO B16a 89-91(Civic Si-R)
- Does anyone know which is.....
- 87 Civic Si HB question?
- problems with just doing rings/valves?
- What's with my stick?
- 91 integra on 91 civic si
- B16a1 vtec question
- Clutch in 91 Civic Si
- crx 86 si hard start problem
