Best Motor for a CRX LS VTEC? ZC? GSR? B16? TYPE R? B20?
Old Mar 26, 2005 | 12:59 PM
StreetRacingCRX's Avatar
StreetRacingCRX
None
Default Best Motor for a CRX LS VTEC? ZC? GSR? B16? TYPE R? B20?
What is the Best Motor for a CRX LS VTEC? ZC? GSR? B16? TYPE R? B20?
My friend who is my mechanic who fixes up cars says LS VTEC will beat the B16 and I dont want to spend a lot of money. That is why I am asking for your opinions. I am looking for power and I want to beat a WRX
Old Mar 26, 2005 | 01:17 PM
Kai's Avatar
Kai
Rotorphile.
If you don't know what an LS/VTEC is and why it makes power, it's not the engine for you. It's not a beginner's engine (ex: B16A.)
Define "best."
Old Mar 27, 2005 | 03:48 PM
mr.crx's Avatar
mr.crx
first of all what do you want to do with your car do you want to drag race it do you want road race all those are to take in to consideration. the ls vtec is the ls bottom end of the integra and the civic si head (b16) which converts it to vtec the reason for the swap on tthe one for the vtec and 2 for the fact that the b16 has a better flow
Old Mar 27, 2005 | 05:51 PM
Snoopy's Avatar
Snoopy
been there done that
:eh:
you can use any b series vtec head. it doesnt have to be from an si.
Old Mar 28, 2005 | 03:45 PM
mr.crx's Avatar
mr.crx
ok well i said that si head just cause that is the most common no need to get offensive
Old Mar 28, 2005 | 03:54 PM
Kai's Avatar
Kai
Rotorphile.
If we're going to pick shits, the SiR PR3 is the most common head. Not the Si PR3.
Old Mar 28, 2005 | 06:33 PM
sherwood's Avatar
sherwood
I missed Sean
:lmfao:
isnt his name in itself a violation of the TOS?
and if you are going for any kind of vtec frankenstien i'd say go all out and do a b20 vtec...
Old Mar 28, 2005 | 07:17 PM
Id probably go with CR/Vtec also.... then again...it might cost you a lot more.... You would need to get the parts individually as opposed to jut getting a B16/B18 and just getting the head/ or bottom on later on as well as doing the conversion for it.
Anyways, i like the cr/vtec setup better, its has tad bit more torque, but like i said, parts might get expensive, you would need the block, the vtec head, axles, trans, shift linkage, ARP rod bolts, a couple more other things to make the setup work.
Old Mar 28, 2005 | 08:50 PM
StreetRacingCRX
None
I have hear a lot of good stuff about the B20
Old Mar 28, 2005 | 09:41 PM
1fasthb's Avatar
1fasthb
Just buy my fully built b20vtec longblock.
