MSD distributer cap and Blaster coil SS
I just got a MSD distributer cap and blaster coil SS. Does anyone know how much this will change my car, such as hp, torque, throttle response. What does it specifically do?
you might as well get a msd 6a, mallory hyfire 6a, or jacobs ignition and some magnecor or other spiral core 8.5 mm wires and do the whole upgrade
right now i'm upgrading entire electrical system on my 944...mallory hyfire 6a - blaster high vibration coil, magnecor 10mm spiral core wires, upraded new battery cables and grounds with kill switch and battery on/off switch
you'll get better throttle response, better gas mileage and lower emissions as the car burns the mixture better b/c of better spark
Thanx for the info, someone told me that I would feel the most difference with the blaster coil and the cap, what specifically does the Ignition 6a box do for the car? Will some better plug wires change anything that much?
http://www.msdignition.com/pdf/6%20series/6series.pdf
if you are upgrading your ignition it is always wise to get new plug wires especially larger spiral core wires (less electrical resistance and better prevents problems with high powered ignitions)
