loss of power
loss of power
My cousing just bought a 91 crx si, but it seem to be weak compared to another friends crx, it has slow acceleration and it seems to hesitate on about 5k rpm. What could it be?
um it could be that the timing could be off a few degrees most likely advanced. because if you retard it then it tends to pick up a little bit if accel. also you can check to see if maybe there are any leaks in the exhaust cause if there are then you wont get the accel that you need or want. also is the check engine light on is reading any codes at all??
Originally Posted by RedlineBoyzCRX
Is your cousin's CRX stock vs your friends slightlty moded CRX? haha
Originally Posted by 1fasthb
Try giving it a tune-up.
new spark plugs cap rotor and wires
valve lash adjustment
check timing
change all fluids
fuel filter
air filter
and check your ground wires make sure they are clean
after doing all this. you may find the missing horespower you are looking for
maybe not a real si?
maybe someone put an si sticker on the hf and tried to pass it off , you know, how people put siR and what not on their cars when they really are not!? I have an hf and i know one when i drive one no matter the gen.
