Gas Leak Help!!!
Old Apr 25, 2005 | 10:20 PM
claudio12472's Avatar
claudio12472
Default Gas Leak Help!!!
89 civic sedan LX leakin gas like crazy! I took a look and it seems to be coming right at or above the fuel lines. Is there a gasket or something that goes bad on these things? I dont like doing gas tanks but i am just seeing if anyone has had any expertise with this stuff.
Old Apr 26, 2005 | 10:04 AM
jaje's Avatar
jaje
HC Racer H5
a lot more information will be useful...like where exactly is the gas leaking from (you mentioned gas tank but didn't say that was where it was leaking) - in other words get up in there and get a good look (take pictures if you can)?
normally fuel lines are connected via a bronze or brass hard line that uses copper crush washers...this is on the fuel filter, charcoal canister, lines attaching to the engine, return lines from the engine back to the gas tank. Luckily I've never had to replace a gas tank or even a pump with my old crx so never had to learn how to do that or even disconnect the lines back there.
