- My TPS on my B16 just stopped working
- 90 civic hb with B16
- My 89 Civic HB has gone crazy. Please Help!
- CRX Swap
- Crx Odd Noise
- 5 speed tranny swap
- 4-1 or 4-2-1
- Wiring Harness...
- Running rich.. anyone know how to correct?
- OBDO DOHC distributor differences
- cold air intake for CRX with JDM b16a
- 91 civic hatchback???
- Festivus List
- Do 93 GSR seats fit in the crx?
- Ignition switch wiring diagram
- Help, my car sucks..
- Fast Car..
- Would a Main Relay make a car not spark?
- 1st b16a redline?
- need help on my crx Code:31,14
- 1990 Civic LX.
- B20 Swap??? also smoggable???
- headlight differences?
- My dellima(thats spelled wrong)
- b16 trans or not
- Who thinks I should go 6 Puck, and who thinks disc?
- 1st b16a plug gap
- Bad Wiring Harness? Need HELP!!!
- replacing brake lines?
- best buy for 500
- test the cooling fan?
- Smoke from steering column.
- Crx b16a2 question?
- All I smell is clutch!
- Nothing Powers on when I turn my car on!
- whats involved with changing the piston rings?
- what is the difference between Saturated injectors & Peak hold
- Who has a lightened flywheel out there?
- Should I really have put a 6 puck clutch in?
- Header Leak Question
- Might be a clutch problem, or 2 much HP?
- Cooling Fan Wont turn off
- black oil in less then 2 month oil change??
- dx brake problems pedal to tha Floor
- 86 crx question on cam
- What is wrong with my b16?
- lower valve seal question
- Turn signal blows fuse when fuel pump is running
- Window
- is it true
- Anyone have a VAFC2 out there?
- Oversize valves
- What are the Torque Spes for the oil pan bolts.
- why does my car still smoke?
- First mod for my car
- dome pistons
- what is
- swiss cheese
- Are there any experts out there??
- springs for crx?
- fuel filter
- Will a B20A bolt up to a 89 CRX?
- 91 SiR RHD coming together!!!!!
- 90 Honda Civic DX HB...
- crx calipers
- Looking for 92-95 civic CATBACK
- rear disk conversion - alignment
- 4wd crx with turbo b17a
- ZC vs D16Z6 swap
- no spark
- how to I tighten my timing belt?
- Shift Linkage Question?
- B16a swap on a 90 civic hatch...
- parts
- '90 Engine Removal..
- delete please.
- rocker arm assembly d16 Vtech??
- B16A1 Auto in a 1990 DX Sedan Possible?
- Bad Main Relay? *Pic*
- Wanted Tranaxle....
- 91 dx camber adjust
- help with 89 dx
- honda parts website
- Wiring Problems????
- 90 civic dx 3dr
- Installing GSR Console 91 Civic Si??
- Header question for my b16 crx
- jdm, which one
- 90 dx hatch
- How much do CTR Cams go for?
- just bought 97 civic LX
- 1990 CRX Si is wat kind of engine?? stock
- 1990 stock Honda CRX Si few Questions. please answer!!!!
- Whats next??
- HELP!!! my car is running on its own.
- Just got the VAFC 2 installed, anyone got tips for me?
- brake fluid leak
- still cold
- my 1988 crx!!
- OBD-0 MiniMe...Which VTEC controller?
- starting issues...
- convert headlights to 9004
- stupid question but I'm curious so here goes......
- What is the benefit of going from OBD0 to OBD1????
- DX to SI manifold
- Newcomer
- EF 88-91 Civic/Crx H22A motor mount kit Now Available!!!$495!!!
- 91 CRX - trouble bleeding brakes
- Civic sedan: trouble starting
- Another Main Relay/Fuel Injector Relay post...
- JDM Side Molding
- CRX wiring harness that attatches to the ECU
- knock sensor????
- A/C Help
- CRX/EF Civic mailing list?
- A/C problem
- 88-91 4 door suspension for a 88-91 crx
- difference: synthetic vs regular
- CRX vs. M3
- 88 CRX suspension??? HELP
- Type of Tranny Fluid
- fuel tank question
- Low Rpm Lag
- couldn't find another place for this
- 85 prelude cv boot replacement
- A lot of smoke out the exhaust from 6000-9000 RPM's
- 91 CRX HF B16a1 SWAP HELP
- ZC What Ecu
- 1989 crx hf wont a h23a1 in it
- Civic losing coolant
- what do you think? fix or not?
- '90 DX not throwing a spark
- trailer arm bout to fall off
- throttle cable?
- civic wagon owners of southern cali
- CRAZY Torque Steer!!! How do I fix it?
- temperature gauge inop
- Really bad tire wear on the inside of my tires!
- Ecu Mpg Now
- Differences in master brake cylinder
- New Civic!
- Gas Miliage Problem
- The bad news....
- Suggested intake
- Tie bar install location (Where are they supposed to go?)
- Choice of Front Struts
- help zc
- How do i paint my car?
- chipping ecu
- D16A9 rebuilding
- Civic interior
- Help Please
- map sensor???
- CRX 1.6D with acura transmission?
- Buying a CRX need expert info
- Interchangeable 99 Civic Parts
- Highest Compression Pistons for a B16a
- eg ek and ef
- Some noob CRX questions.
- Please Help
- sohc zc and d16a question.
- b16a in crx and keeping a/c questions
- B18A in a 1988 crx dxHELP!!
- Uprgades worth buying?
- Turbonator
- age old fued
- why could this be happening
- Main Relay?
- What a good turbo And what's going to give first !?!?
- Weight
- 1990 honda civic tail lights
- 89 civic spd. cable into jdm b16
- What's easier?
- K20 CRX Video
- need d16z6 head
- Wanted a 89 Civic Si chassis or car...
- what is it
- anything i can do to prolong cv boot life
- engine light on all the time
- Intermitent Problem
- axel nut no go!!!!!!!!!!!!!!!
- Where Does The Trans Fluid Go In The Crx?
- White Smoke.
- B18a block
- Si ecu into DX port???? HELP
- advancing the time
- Will I weigh my car down with a body kit?
- 1990 fuel injected manifold help!!!!!!!!!
- b16 wiring into a crx si 88
- Are You Rebuilding A B16? I Got Parts 4 U!!
- transmission oil filler bolt
- Swaybars for non-Si cars?
- a good 5 speed tranny?
- Is 15x7 the right rim for a CRX?
- obd0 on obd1 motor?
- CRX Rear Mount - Finished
- Anyone Know???
- 88-91 lik kit????
- Is NOS worth buying?
- Apexi VAFC2 Mounting Spot in a 91 CRX
- Help finding an engine (not in California......)
- 91 Crx Hf B16a1 Swap Help
- 91 civic problems
- suspension help?
- check this
- convert dual point to multi port
- Need help with my 89 CRX Si
- CRX Rear Mount Progress
- Building a Sleeper
- MMph.. WATER OUT OF EXHAUST
- Theoretically Speaking...how much to replace a front axle on 86 Civic?
- a little help?
- whats the difference?
- fuel pump fuse problem...
- CRX, Civic, Del Sol parts for sale
- ecu code question
- door replace(wiring harness)??
- What are the best struts for CRX with Skunk 2 Coilovers?
- strut bar question...
- what do you guys think about my car???
- CRX engine swap in california - what do I need to know for smog/emissions?
- Single overhead cam zc in crx
- zc head on a d16a6
- d16z6 swap
- Parting out my 88 CRX w\ a D15B
- Ha ha ha...
- obd1 conv req's
- cup holder
- honda crx is overheating
- JDM/OEM/Spoon/Mugen
- Update on Problems...
- obd0/obd1 conversion
- b16 electrical problems PLEASE HELP
- Any sedan guys here?
- VAFC 2 vs SASC
- VAFC 2 vs SASC
- b16a1 swap into a crx si
- obd0 to obd1
- 2nd gen b16 what would u do
- 89 CRX si main harness
- Price For Swap - Good?
- Building a CRX to Drag
- good turbo for a d16a6?
- Got my new wheels on!!!!!!!!!!!!!
- adjustable cam gears
- Radiator Fan
- b16 crx stock 1/4
- Brake Rotors
- b16a CRX
