View Full Version : CRX & Pre '92 Civic
- 93 gsr dash into a 90 crx
- Oil for my B18a1
- checking engine compression tomorrow
- I'm Back! - Just Put Money Down on a New EF
- Haynes or chiltons manual...
- could the main relay be the problem
- prolly a stupid question. but dont hurt to ask..
- ecu codes
- blue exhaust smoke.. help or suggestions anyone please?
- 5 speed
- Fuel filter
- k sport kontrol coilovers
- ZC ECU Problem
- ZC head
- How to date check a PM6 ECU?
- need parts
- 90 Civic Hatch Guage cluster
- Crx turbo pics, finally took some!!!
- DX to ZC swap
- b18a problems
- ***axles Help Help Help********
- crx 1990 si tranny into integra 1989?
- si wiring help
- Crx muffler question
- 2 seconds for a noob.. please
- ******crx******
- AC belt necessary?
- d16y intake manifold
- FYI: '91 Prelude seats into a '91 hatch - it's not easy
- glow gauges
- F***ed Up Engine
- could a spark plug being loose or defective cause misses with idle...
- Struts & Sways
- pm7?
- Turboing a ZC(d16a6)
- Exhaust manifold clarification...
- dash cluster lights not working now...
- Brake repair fiasco. Who should pay for the cracked radiator & more?
- idle issue
- RE:Starter
- this sucks
- 14mpg not so great
- 87 Si Axle Replacement
- JG Edelbrock Cams?
- let me know what you guys think tein s-tech drop
- Wheel/Tire Selection....
- 91 civic ground locations
- ok so i installed a new intake manifold car doesnt start and new code........
- victor x manifold questions
- 90 Hatch Seat ?
- zex smart kit?
- Full coilovers available for the rex?
- which motor should I go with
- rubber moldings. Can I get plastic replacements?
- My Vtec crapped on me
- Prospeed header...
- i am looking for a jdm crx
- 89 crx need help ( NO POWER OR LIGHTS)
- 3 days left now!!! someone has to know..please!
- mpfi conversion ?
- I need help please, please...
- How do I get power...
- ZC Engine
- 4 days left:( I need help!!!
- d15 vtec help!!! crank sensor code in limp mode!
- ***92-95 civic rad fan in crx, help please!!!!!!
- 4th gen 4 door auto-x-forced induction
- Trying to find...
- How do you tell apart real mugen bumper from fake?
- how would i install jdm folding mirriors
- how would i install jdm dc2 gauge cluster
- Moonroof rattling
- Wheels/Tires
- Does anyone know where I can find...
- Fuel pump going bad? What are symptoms?
- k2o crx
- dohc zc
- 1987 CRX - Damn its hard to work on.
- Header Install = Radiator Clearance Issue
- 1990 CRX Cranking, but won't start.....Please Help!!!
- bumpers on my ef
- Car won't start after camshaft install (urgent)
- b16 in CRX estimated times..
- Weird Idle after part install and removal
- 1987 crx wiring diagram
- Checking compression
- ECU Question for DPFI to MPFI swap.
- question about swap on my ef
- 1989 Honda Civic DX Series of Problem
- painting hatch: taking it apart & putting it back together
- reading 89 civic ECU engine codes
- Lights on reminder?
- Best year?
- crx for 850?
- i have a few Qs
- Where can I get a filter like this?
- Has anyone seen one?
- timing belt
- OBX intake manifold. Should I get it?
- axle question
- Civic Wagon clear corner lights
- civic wagon main power relay info
- how dose this come off???
- Is my engine really screwed??
- Are CRX headlight interchangeable?
- need tranny info
- Header Install Question 90HB DX 1.5
- msd and tach hook up
- 97-01 itr into 91 crx dx
- Found my motor
- CRX compatibality
- CRX Vacuum Hookups for B18A ???
- sleeper or show??
- turbo???
- Tranny needed for 91 Si.
- bad starter?
- 02 Sensor Position 90 HB 1.5
- looking for an STS2 car
- CRX Amplifier
- Steering wheel size
- Will this fit?
- drivers door window weather strip
- Brake question
- YS1 Cable Tranny won't shift!!! Help!!!
- Idles at 3K?
- cf trunk?
- One-piece Front Ends?
- crx jacksonracing supercharger question
- 89 CRX Purchase question
- Crx Question
- Need Pics Of Turbo Setup!!! Help Please!
- 91 CRX brake pedal goes to the floor... HELP!
- 86 crx rebuild
- Is 12 MPG a little bad?
- Wiring RPM gauge cluster
- my next question?????? someone help
- RE:Starter??
- Rear hatch question
- rex question?
- Help???? B18a1 in a 88 crx........
- Time to swap
- Please help, car acting weird.....
- keyway size?
- 92-95eg suspension upgrade?
- trouble shifting in new hybrid
- wheel bearing replacement
- CRX Tranny To buy or not to buy?
- need wiring schematics for rear wiper
- K Series!?
- d15b2 conversion to d16z6
- Still not Starting
- need help on my new project! PROJECT EF
- i need help with a d16z6 swap obdo to obd1
- valve clearance
- fuel filter
- Charging light intermittant to always on
- Removing the dash...
- can clogged injectors...
- Four wire o2 sensor hook-up????
- Anyone know if fuel injector cleaners are good or bad for the car really?
- Step on gas but lags, like not getting gas then...
- Help with replacing 91 civic DX starter
- they say I have loose wheel bearings??
- d16a in a DX with DPFI?
- b16 swap running badly!
- B16 swap..running badly
- exhausr question
- 88 crx axle
- P30 wiring diagram
- d15
- H22 swap into a 88 hatch???
- What is a STD hatch
- Help!!!
- Will a regular civic metal inner bumper fit a CRX bumper cover?
- replacement clutch
- strange starting issue
- starting question
- transmission shifter forks
- Wheels/Tires for autocrossing CRX Si
- low zc power?
- How long can i drive with no boot?
- head gasket/overheating question
- 91 civic wheel bearing help
- 87 moldings
- exhuast question
- S1 Tranny Synchro Replacement
- Where's the Main relay.??
- crx si rear sway bar
- ZC oil filter help
- B16 Idleing at 2000 RPMs Please Help.
- pre-88 crx's
- dpfi to mpfi???
- so, i need a synchronizer for my tranny...
- will '92 springs fit on a '91
- engine wiring diagram for a 1989 honda civic dx hatch
- car shakes when brakeing at high speed
- Hood clearance problem
- price for complete zc swap
- car wont hardly run...
- need to go on a diet!
- weird starter issue
- What do i need?? new o2 or maybe just another one??
- 84 civic transmission help please
- I need #'s for LMA's
- Civic kinda bucks at low speeds/idling. [HELP]
- swap
- Someone's stealing my brake fluid...
- B16 axle and clutch cable problems
- So i decided on a basic ZC swap.
- brake light on/off switch
- 88-89 door window???
- need help with codes and more
- want to paint rims
- So i wanna swap a B16A(SIR-II) into my 90 SI
- 90 Civic - no sparky
- Seattle: yello '90 CRX Si stolen, tell me if you see it
- low hanging exhaust
- Starts, but immediately dies...
- EF w/ K swap?
- VTEC Solenoid Question!!!
- finally doing the swap
- Exhaust spring bolts?
- Starter help!
- 88 CRX fule pump removal question
- obd0 to obd1 wiring help
- 1989 civic crx Si. Just purchased, need thoughts.
- spare tire question
- No start on CRX, need serious tech help
- 91 CRX si, Overcharged Battery?
- 89 Ls-vtec Hatch
- new to the EF thing
- Door Panel Patches
- lights problem!!! maybe wiring......
- Accident report w/ pix... (56k be careful)
- d15b7 turbo help
- Are my valve seals bad?
- mpfi swap
- best way to pop dents
- wheel vibration
- brake swap questions
- 88 crx rear mount
- Car Primer
- Leak help.
- can you run 2 ecus with a switch?
- does 1989 crx tail light fit 1990 crx si?
- Would steering wheel from a 92-95 fit a 90 crx?
- Crx
- Sunroof
- i need help ASAP
