View Full Version : CRX & Pre '92 Civic
- the nightmare has ended
- single cam vtec zc clutch...
- this guy is crazy or so i think lemme kno
- Crx idle prob's
- Got pics of dirty hatch
- CRX JDM Backseat?
- crx/91 civic custom interior???
- 89 crx vs. 91 civic dx
- general questions...
- What grit Stones do I need for a Cylinder Hone?
- How do I get the Crank Pulley off of my car?
- What type of valves would be better?
- Tail light Type on a 91 Civic DX?
- Newbie.....Seeking info on B16
- No air
- '86 CRX Si drop-in motor?
- Question about new pistons with stock rods!
- Best sites for auto parts diagrams/pictures?
- H22 Or B20?
- Engine Upgrades?????
- Electrical Load Detector(ELD)
- vtec wiring options
- 89 crx ls swapp NIGHTMARE
- Speedometer not working, solution anyone?
- what will a crx beat in a drag race?
- Vtec not working
- What is the Best EMS for running a turbo?
- lost of power
- Clutch question.
- Resonator removal question
- throttle body coolant bypass mod?
- headers?
- camshaft work
- does this sound legit?
- itr swap questions
- Weird (popping) sound!
- Another ecu question
- B16a1 Engine Manual
- HF to ZC swap wiring and other questions
- need help for 89 crx engine swap
- 1991 1.6 si motor computer question
- silly obd1 dohc zc
- '91 Honda CRX (Inoperable Takometer)
- Whats your opinion?
- Type R P73 Pistons
- what wheels for CRX/Integra hubs
- PG7 ecu swap
- Looking for Honda Part #07999-PD6000A
- crx 1.5
- autometer air/fuel installation
- b16 ecu question.
- Jackson racing supercharger question
- Will a P73 Piston fit onto a PR3 Rod without anymodification?
- Is this electric supercharger a P.O.S.?
- compression for turbo application??
- Best cold air for b16 crx?
- b2 and b7 head swap?
- CRX d16 needs dual overhead cam vtech
- d15b7 cam into d15b2 head
- Instructions for Installing Valve Spring Retainers
- Where do I buy more Valve Adjustment nuts?
- tranny help
- 89 lx 1.5 cam/crank timing question
- Advice on Alternator
- Crx swap need little help
- New head bolts a MUST?
- cigarette lighter install
- How is this Turbo Kit?
- corner lens
- Alternator won't come out!!
- Fuel, where for art thou?
- cd player
- CRX Problems
- How do I get the Check Engine Light to flash?
- Brain fart on compression test:
- Is a Aftermaarket Crank Pulley Better?
- like a f***in helicopter!!!
- head gasket
- Whats The biggest engine that you can out in a 90 crx si?
- d16a8\9 internals
- EACV 1st gen Si
- 1991 CRX 1.5 won't start
- Carpet for my Civic....
- My car is runnin' on 3 cylinders. HELP!
- What is Code 6?
- One-peice headlights for an EF8, where???
- nitrous
- Finally made my way back...
- 90 Civic axle (CV?) boot
- 90 civic hood problem
- crx runs lean under acceleration, please help!
- Main Relay Q.
- b20/vtec
- 89 CRX with B16A - Stumbling
- Junk Yard Wheel Bearing????
- Another code 12 puzzle, maybe cvc?
- the killer 89 rex
- starter solonoid fuse keep on burning out
- CRX 88 vs 90
- help honda engine swap
- Car was working fine, now it won't start!
- Crankcase vetilation question.
- valve seals/seats....whatever
- service port
- which throttle body gasket LS or SIR
- Dammit all to hell.....
- Need Moe's Help
- EP seats in my EF?
- obd1/obd0 ((dumb question))
- 88 Civic/Shifter Boot....
- clutch engaged, car wont move no gear
- How Do I Know If my VTEC Solenoid is going bad?
- can i run a pg7 ecu on my d16
- 1st gen CRX SI motor swap
- 89 Civic wont start...
- 88 crx NEED A CLUTCH
- EP seats into EF?
- Threadlocker on crankshaft pulley bolt or not?
- My VTEC Won't come on
- Headgasket Question
- Exhaust question
- My car died but will still crank??
- Motor mount question
- CRX won't crank, stumped, need help, very detailed info
- 91 to 92 suspension possible?
- Code 8
- I don't remember changing a timing belt being such a p.i.t.a.
- b20b in a rex
- questions on exhaust applications..
- What are the differences b/w 88-89 and 90-91 CRX front ends?
- How to get the dang flywheel bolt off?
- 91 CRX Will not Start *please help*
- flashoptions any good?
- car stall out at about 6k
- D16Y8 Mini Swap
- need help here guys..crx died on me??
- Mini-Me Swap Help
- Will not having an O2 sensor be that bad?
- D-series performance parts compatability?
- please help 96 civ ex
- obd0 to obd1 question
- question about D15B engine
- Motor Swap
- How much are you paying for insurance on your crx?
- lack of power... 88 si
- The New CRX?
- engine check light
- Temp gauge going to hot in seconds!
- Car Engine Computer ECM
- B16 Cams
- Please Help
- Idle on Civic
- 1990 Civic (hatchback)rear speaker removal
- side skitrs.
- 89 and 90 differences?
- ***out with old, in with the new, civic to rest-crx new project****
- Swap
- coolant temp sensor/gauge not working
- timing
- crx hesitate on 2 and 3 gear?
- leaking coolant from oilpan
- mpfi help want more hp
- Embarrasing muffler
- Firewall harness Install
- 1 Layer B Series HeadGasket
- How can you tell if your piston rings are bad?
- help please
- need electrical help for 88 crx si
- Swapping blocks
- need help with possible motor swap
- Tachometor for an '88 civic...where??
- Mystery No Start -- Please help.
- Exhaust Help
- Should I get an Oil Catch can
- Does the front ground wire on the car matter?
- How do I adjust my valves?
- Question/spark plugs
- Where to get a O2 sensor for a OBDO B16a
- 99 civic si knuckles/hub/brakes in 89 crx
- Test Pipe vs. High Flow Cat (What's the Diff?)
- My exhaust Sounds raspy when it hits VTEC.
- Introduction & Question - drivers window
- engines
- Wheel bearing question
- Why not an H22A?
- Help Me Im Stuck In Europe
- Megan Racing Header
- I lose brake fluid evry month!
- Wheel Bearing Help??
- 92 Honda Civic
- performance
- No brake pressure?
- CAI question
- D16a Mini Me
- noise
- Question About Muffler Please Post!!!!
- He
- Crx suspension
- Just got another crx
- Setting a TPS
- ZC Oil filter
- Swap or Suspension?
- multi port manifold on d15b2
- CRX DX rear muffler on 88 DX hatch fit?
- 88 si overheating...
- Dohc zc in 91 crx si question
- What would a Bad IACV cause?
- difrence
- dustributor wiring help
- Under hood spray help!!!!!!!!!!!!!
- V-tec not turning on??
- Need Advice On Crx Purchase
- Droppin my CRX
- swap, or bust
- Car Trouble
- kyb struts
- Opinions / Technical Q's on Swap...
- d16a cam into a d15b2
- Falken Ziex Ze 512, anyone got em
- Shaking at high speeds, tires??
- new headers...new exhaust leak
- ls swap, exhuast????
- Help With My 90 Civic Ex
- d15b7 head to d15b2 block swap Q's
- engine number
- cam gear
- Name that part :)
- 89 CRX Steering problem
- Radiator Problems.
- problem starting car!!
- Location of EGR valve on 89 STD HB
- 90 Civic Coil Cover Help Please
- Looking for a swap?
- So my O2 sensor isn't hooked up to anything...
- d15b vtec??
- Has anyone installed a firewall harness before?
- Does anyone know if they make an O2 Simulator for OBD0 B16?
- Need D16 or D15B in Germany
- NO BS PLEASE D16Z6 vs D15B VTEC (JDM)
- Exhaust leak?
- Steering Wheel Adapter....Where to get one cheep?
- EF Mugen Pro.2
- Hissing noise comming from exhaust
- trying to increase more hp out of my b16 in my crx
- Sri Sound
- How do I adjust my IACV?
- Electrical problems...
- Asked and answered before now it's my turn!
