- Lowering question
- Jazmin?? Jasmine??
- 88 crx interior in 91 civic HB?????
- intake manifold and TB?!?
- throttle cable?
- distributor replacement (need part number)
- RIM Size relating to steering
- RIM Size relating to steering question
- Gas Tank
- need help which wire should i cut???
- Weird "stumble" on Acceleration
- See who can figure this out...
- Fuel to air ratio
- Convertable CRX
- Dx head on Hf block?
- AC compressor kicks on/off after conversion to R134
- b series swap in 1st gen CRX
- Engine problems please help!!
- Transmission...and Fluid?
- code 6 only in reverse gear???
- Bent Studs on Wheel Hub
- What you guys think?
- question
- glass roof
- hello all, im a newb and i was wondering if i could put a h22 in a 89 civic 1.5L?
- mugen b16 valve cover
- civic 1.6 ZC JDM SOHC for my 84' crx?
- clutch?
- 91 CRX HF Code 16
- brake light wiring help
- need pic of ls motor in hatch
- Resistor box for ZC swap?
- radiator
- HELP! Problems removing oil pan on '88 CRX DX
- DPFI/MPFI and TRANNIE?
- WTB: 88-91 CRX SI in WI
- Legal CRX Projects
- Swap on a budget? what engine...
- Block Sleeves
- Camber kit question...
- Prothane Motion Control Bushings
- A/C Power Problem on 88' CRX Si
- crx bumper ef8
- project crx
- HIDS on civic DX
- Rota slip 15 x 7.0
- b16a swap 02 sensor problem
- what car is this steering wheel from?
- Where to get transmission syncros etc?
- Which seats fit an 89 Civic hatch?
- swapping seat pans.
- ecus
- Engine rebuild? Too much oil is burned up!
- Tire ballancing problem
- Automatic question
- leaky water pump
- Front License Plate Bracket?
- CRX Subframes
- Gsr
- dp-mp fuel injection
- crx a bLaZiN
- B18 swap for 84' CRX is it possible...
- goddamn check engine light and clutch
- crank shaft bolt, normal or reverse?
- d16a6 block with d16a3 head
- my friend needs some help
- Dash Help?
- CRX with a ITR motor HELP
- V-AFC and cams
- oil in spark plugs!!!
- just got 88' CRX what can i do.......
- hot wire a civic?
- 94 civic hatch rear speakers and road noise
- b18a1 auto into a 91 dx auto
- b16a dying?
- My newest addition
- JDM sidemarker alignment
- camber questions
- Engine swap 84' CRX
- Say your 2cents about engine companys
- engine swap into 87 hatch
- Backseats?
- 1st Gen Dx to SI
- rear disc
- headlights?
- Ignition rotor problems 89 civic
- Is This Possible? Horsepower Question...
- 87 honda civic LS
- CRX SI needing saved
- 87 integra ECU better>?
- roof panel
- A/F gauge hook up HELP.
- help new project!
- Noise when Seatbelt is Unfastened
- b18 wiring advice
- Fuel pump specs
- f22b1 swap?
- 89 CRX running really rough, need help
- good price for clutch & flywheel swap? (labor)
- CRX bumper
- Auto X
- What is this???
- what header with ls in hatch
- quick question about tail lights
- 86-89 Integra engine into 87 Crx SI
- brake light help?
- quick questions
- An F20C Swap?
- 1990 Honda Civic Wagon RT4WD
- need help with vacuum hoses on hatch with LS
- HELP! Smoke!! Yikes!!!
- 1986 CRX Si
- Nos???
- 92EG6's Custom Sway Bar Brackets!!!
- Bolt Mesurements
- B18C Motor mounts and D15 BUILD UP
- Ball joint style camber kits
- D16Z6 Swap into 86 CRX SI
- ZC motor question
- shift linkage on 91 hatch with ls
- HAN members: Falken Azenis Groupbuy 205/50/15
- zc dohc valves
- new motor. now what?
- o2 sensor Q
- crx swap
- Piston stuck, car wont start.
- fix it ticket
- car wont start help!!!!
- XENON lights
- exhaust flange question
- questions on my ls hatch
- most power
- so you wanna see top speed on a crx?
- alignment help
- CRX Panels Where can I find these?
- cry02 ?
- Turbo tube?
- Just picked up a 90 REX
- gas smell
- front end conversion on a 4g civc
- CRX Rear Arm Rests How much should I pay for them?
- break help!
- rear bumper removal
- clear bumper lights
- Front bumper
- 1990 CRX SI FOR in PA
- wiring for ls into 91 hatch
- edm pearl hatch ---EAST COAST---FOR SALE
- Exhaust interchangeability
- gauge doesnt work
- CRX gauge needle illumination out...
- Will a d15b7 intake bolt up to d15b2 head?
- Motors...
- Need help removing my rear seats!
- dent in fender well for b18?
- crx swap
- EG conversion..need help
- Is this right????
- squeelin pulley.
- what kind of exaust system?
- leaking tranny
- oem headlights
- So I tried Starting my 89 Crx Si today...
- ODBII to ODB0 conversion.
- woowoo I picked up my crx si today...
- Best Place To Find & Ships To Canada??
- Problem with B18c1 shutting off
- website for b18 swap?
- greddy
- Exhaust Rattle (pic included)
- crx : h series or b series
- B16a Swap Help
- CRX swap D16Z6
- homemade turbo questions
- LS VTec 1/4 times?
- fuel injectors??
- Where to get an SiR bumper
- b16a cold start..
- New front lights
- 99-00 fog lights on crx
- Updated pics of my project HATCIE!!
- 89 Civic CX info wanted
- Coilovers
- What's it take
- could i put a h22 into a crx
- AEM 92-95 Civic Intake
- Price for a CRX
- Rear Wheel Cylinder
- valve cover
- headlight adjustment?
- stalling
- type R tranny grinding
- Damn Clean Ass Crx Si
- Rear GSR seats in Hatch
- Hatch leaking AGHHHH
- 91 civic with D16y6 swap quetion!?!
- starting problem? 90 Civic dx
- Economical Axles for 1990 Civic
- 87 zc-1 crx to d16a8 swap
- b18 in 89 4-door.
- Need help with CRX not starting :(
- no sound from my intake?
- CRX price flop?
- F22a1 in my 91 hatch si???? possible?
- What engine should I put in my 89 civic dx hatch?
- need dizzy help with 91 civic hb with a 97 d16y7 w-(mini-me)
- Air filters: 88-91 CRX DX and Si same fitment?
- :FAQ: How to Remove CRX Door Sill (56K Death)
- :FAQ: How to Remove CRX Door Panel (56K Problem)
- :FAQ: How to Remove CRX / Civic Steering Wheel
- CRX / EF Civic FAQs and other Usefull Links
- CRX for sale...
- 90 DX "clunk" ???
- 90-93 integra springs/shocks on 88-91 crx?
- bseries mounts..?
- b16 1/4 times
- dash conversion?
- parking light wire?
- tire rods
- CRX DX tranny
- Bent rim - possible to repair?
- Bodykit question Hatch front bumper on crx
- special bolt goes from block to tranny?
- Oily-looking coolant
- help with my tranny install!
- Shift linkage & starting problems
- Coolant system problem
- Turbo for sale!!!!!
- Helpppppppp!
- Has anyone had this?
- this may sound like a stupid question....
- Bent Frame?
- 89 crx si motor swap questions and comments
- new rex/needs quarter panels
- What the hell is this?
- b18a turbo???
- axle clicking
- b18a diagram
- Help me choose my new suspension setup.
- Beating A Dead Horse I Know...
- 91hb si ---88hb
- Crx For Sale 800 in CT
- Convertible Crx With Original Body Kit
- any first gen b16a know what this is?
- tranny slipping?
- squealing sound at low speeds
- CRX dedicated web sites
- Dead CD player 89 Civic
- injector clip color?
- What kind of adjustable shocks should I use?
