injector clip color?
i know this is a dumb question, but arent obd0 injector clips the off cream colored ones? my 91 civic has grey clips and no resistor box:dunno:. has anyone heard of this?
I don't know what motor was swapped into your civic but you're running OBD1 Injectors if not an OBD1 motor as well. Three ways I know... The injector clips are grey; The Injector wire feed box is the OBD1 shape (L shape rather than straight through); and you have an empty plug where the injector resistor box would have been along with a bolt in it's mounting hole
Originally Posted by e30dood
What car do you have? More importantly, what engine do you have?
basically i just want to know if i should find a set of obd0 injectors w/clips, resistor box etc. and swap it, or will i be fine the way i am now? thanks in advance.
It should be fine... When running OBD0 inj. you must use a resistor box; and when using OBD1 inj. always go without. I'm 90% sure of this. If you find out otherwise/decide to use OBD0 Inj. then hit me up cuz I have the injector resistor box, inj. clips w/ all wiring to the resistor box, plus the injectors... all from my old 89 CRX HF motor... Last month I swapped in a JDM D15B Vtec
Tang
Showroom
14
03-04-2004 11:42 PM
NSBTypeS
4
03-31-2003 06:05 PM
