leaking tranny
Old Mar 30, 2004 | 06:00 PM
sick79's Avatar
sick79
Default leaking tranny
can anyone tell me what seals are replacable on a trannie? my si trannie has a fluid leak, and im not sure what seals are possible culprits.
i know its the trannie and not the engine thats leaking, and its not the drain or refill bolts that are loose or improperly sealed. any advice will be greatly appreciated. thanks.
Old Mar 30, 2004 | 07:39 PM
jlicrx's Avatar
jlicrx
seals where axles go into transmission, seal at input shaft, seal at speedometer gear and seal at shifter
Old Mar 30, 2004 | 07:51 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
main seal
Old Mar 30, 2004 | 10:26 PM
Redlinerz's Avatar
Redlinerz
most likely axel seal..
Old Mar 31, 2004 | 09:24 AM
jc836's Avatar
jc836
If you see fluid on either axle-then the chances are good that the shaft to case seals need replaced. This is a common issue when the shafts are pulled out and reinstalled. Some people are not real careful and the seal can be cut.
Old Mar 31, 2004 | 10:39 AM
sick79's Avatar
sick79
im pretty sure thats what it is then, and i know the axles were removed by the previous owner. do i have to crack open the trannie to replace those seals, or can i install them just by pulling the axels?
thanks to everyone that responded, i really appreciate the help.
Old Mar 31, 2004 | 12:05 PM
Kai's Avatar
Kai
Rotorphile.
You can easily get them out by just pulling the axles.
Old Mar 31, 2004 | 03:51 PM
sick79's Avatar
sick79
thanks, guess i have another project now.
2 damn dark
92+ Civic/EL & Del Sol
3
Sep 4, 2003 03:11 PM
vick911c
Accord
Apr 1, 2003 08:09 PM
SumAccordGuy94
Accord
Dec 16, 2002 02:54 AM
eclipse spanker
13
Oct 10, 2002 09:17 AM
