help with my tranny install!
RacinMasonC
Okay i can get the tranny up to the engine but the spindal doesn't wanan slide in the clutch disc.. like it gets stuck then i have to let it down. anyone got any help on how to do this by yourself? PLZ
d16a6 engine btw
Mason
d16a6 engine btw
Mason
PC's_N_CaR_EnGiNEeRiNGMaN
hey
kai is right. is that the trannie that came with the motor, in which you pulled it off and are now putting it back on? clutch alignment tool, did you use the correct one and was the disc properly aligned to the pressure plate before you torqued it? ask a friend to help a hand, when i did my first clutch replacement by myself a long time ago, it took me an hour to not get the trannie on the block, i asked a friend to help out (he lifted the block, myself the trannie) and after turning the whole trannie left to right while trying to slip it in, it mated (took only 3 minz with 2 people). good luck, 2 or more people are better than one sometimes, remember it takes a little effort and you may have to force it.
Shadow Lurker
Hey Mason, It's TomO. Are you trying to install that ZC hybrid tranny? Just make sure that you used a clutch alignment tool when you bolted down the pressuer plate. And grab a second person to help, that is the fastest, safest, best way to do it. If you still are having trouble, hit me up on AIM: EF18a and we can talk about it.
TomO
TomO
RacinMasonC
yeah tom and the other people, i did use the clutch alignment tool but i think i figured it out, Tom if you talk to james he could tell you.. i didn't know i shouldda tooken off the front tranny mount.. that wouldda helped a TON b/c it kept getting stuck on the radiator fan damn James.. lol. i'll try it later sometime tho.. if i can't get it i'll talk to you or James.. thanks guys!
RacinMasonC
yes also the ZC is going in.. and yes i check the clutch disc and it fits on.. i guess its just a biatch and you have to turn the tranny back and forth while pushing in...
Shadow Lurker
Yep, it can be a real B-iotch to get a tranny in if you don't take off the front mount and even sometimes the radiator. It takes quite a bit of wiggling and jiggling to get that in. You will definitely like the end result though, that tranny pulled like WHAT when it was in my car, and shifted Ubersmooth for me. :af:
S2000 Pilot
Just have someone get under the car and bench press it up and someone up above lining it up. The trick is getting it completely level or the splines wont' line up.
Rotorphile.
The last time I had to swap my transmission (blown countershaft input gear) I benchpressed it up and jiggled it in. It took a little while, but the splines eventually lined right up and it slid in all the way to the block. With a bit of arm strength and some patience, it's not that bad.
