brake light help?
Old Apr 18, 2004 | 08:40 PM
menappi's Avatar
menappi
Default brake light help?
hey my brake/parking lights all the suden arent coming on. idont know which fuse it is, i looked in my manual and cant figure it out. well im hoping its a fuse, cause my instrument panel lights work fine, my horn DOESNT work, and also when i press on my brake, my DOOR light comes on (the light that shows an open door)...WTH is this? any help? my lights are plugged in and the bulbs are good also.
Old Apr 21, 2004 | 08:06 AM
Pete's Avatar
Pete
Civilian
you know I had the same problems about 4 months ago. It turns out that I had a few wires shorted and crossed because the previous owner massacred the electrical system. There should be a map of which fuses do what on the panel that covers them under the steering wheel. If you can't find a map there than you can probably find one in a search engine or something. Anyway, check thourougly under your hood on your electrical wires. If you have wires under your hood that lead to nowhere or crossing wires, tape the ends of them off with electrical tape individually or cap them off. After you do all that, than check your fuses, because crossed and shorted wires can cause them to blow. I went though like 4 fuses just installing my cigarette lighter plug if all else fails, I'm sure a mech will take a look at it and let you know what's wrong (just don't pay him to do an easy job :P)
Old Apr 21, 2004 | 08:54 AM
kd5dbl's Avatar
kd5dbl
According to my Helms... the fuse for horn/brake lights is number 35 in the fuse panel in the engine bay. Should be a 15amp.
Good luck
Old Apr 21, 2004 | 08:58 AM
kd5dbl's Avatar
kd5dbl
Oh yeah... being that your parking lights don't work, but your dash lights DO work (they are on the same fuse)... then you likely have a short/open problem in wiring.
Just for the record, the main fuse for lighting is #33 in the engine bay fuse panel, but the parking lights are fused again in the dash panel #8.
adamdaviddoyle
Accord
6
Nov 10, 2003 11:58 AM
Croc1178
Accord
4
Jun 27, 2003 07:20 AM
teincvc79
92+ Civic/EL & Del Sol
2
Mar 27, 2003 02:59 PM
titaniumGSR
Aug 29, 2002 10:03 PM
