code 6 only in reverse gear???
Old May 17, 2004 | 01:12 PM
4gCRX's Avatar
4gCRX
Default code 6 only in reverse gear???
Yep, thats right...when I put it in reverse the ecu throws a code 6(ECT). Turn the car off and turn it back on....no code. Put it in reverse the idle drops, tach bottoms out then bounces right back up then the cel lights up. The engine doesn't act like its going to die, just a quick drop in idle then right back...like 2 seconds. I also hear the main relay click when this happens. The main relay is about a month old (bought from Honda) and has checked out ok.
Any ideas?
91 CRX HF
b16a i/h/e
pr3
obd0
S1 Trans.
Old May 17, 2004 | 07:28 PM
jlicrx's Avatar
jlicrx
HF ECU received signal when back-up lights came on that increased the idle - go to ECU and cut the wire at pin B9 - should be green with black stripe - should fix the problem
Old May 18, 2004 | 03:21 AM
4gCRX's Avatar
4gCRX
Cool, thanks!
nikkim
25
Jan 10, 2004 06:28 AM
89waggy
CRX & Pre 92 Civic
8
Jul 21, 2003 08:31 AM
civicInfuZion
14
Jul 19, 2003 12:18 AM
muff diver
CRX & Pre 92 Civic
9
May 26, 2003 08:17 PM
exzeltus
7
Mar 12, 2003 03:50 AM
