camber questions
Old Apr 25, 2004 | 01:30 PM
AppleSauseSi's Avatar
AppleSauseSi
Critical S.O.B.
Default camber questions
I'm going to get a set of Eibach Sportline lowering springs (1.7 inch drop) and I wanted to know a good place to get a good camber kit. Also what's a good brand and what degree I should change them too if I want my tires to ware like stock.
Old Apr 25, 2004 | 03:05 PM
Kai's Avatar
Kai
Rotorphile.
Stock spec is something like one degree negative.
Old Apr 25, 2004 | 03:33 PM
slammed91-hatch's Avatar
slammed91-hatch
that little of a drop won't even bother your camber.
Old Apr 25, 2004 | 05:51 PM
yeah when i dropped my car...my camber wasnt too bad....i dropp the front 1.5" and the back 2" i beleive, i cant remember anymore....anyways unless you've got pretty big rims around 17s....then it might rub a little...really depends....with my 17s on it kind of rub....when i borrowed my friends SIs they didnt....
Old Apr 27, 2004 | 08:34 AM
pisetup's Avatar
pisetup
User
So lowering the car, lets say 1.7 in front and 1.5 in the back - you wont need a camber kit?
Old Apr 27, 2004 | 12:49 PM
jc836's Avatar
jc836
One more time-get the car aligned! You CANNOT possibly determing what if anything you need without a printout from the machine. I will agree that small drops under 1.3" will probably be close to the outer limit of the alignment spec-BUT there is no guarantee. If you can live with the tire wear that comes from NOT aligning the car, so be it. If you want correct tracking and Toe then the alignment is a must. Then and only then do you decide on kits.
Our CRX has kits from SPC up front while the rear uses longer bolts and washers. Both SPC and Ingalls have various solutions that will work well.
As an example of what to buy-we used SPC 67135 on the front of our '99 Prelude BASE. The rear kits are Ingalls 3571 and 3573. SPC also has a solution for the rear that works on both BASE and SH-the rear of ALL 5th gen's are identical in the US version of the car. Where to buy your parts is up to you-but I get mine from Ultra Performance in Tucson,AZ.
You got Q's-drop me an e-mail.
IamNemo
Accord
10
Apr 17, 2004 05:27 PM
Coldsun
Accord
3
Aug 9, 2003 11:17 AM
agent87
92+ Civic/EL & Del Sol
5
May 9, 2003 07:53 AM
smakdown
Accord
3
Sep 23, 2002 01:39 AM
accord_vti
Accord
6
Jul 29, 2002 12:49 PM
