need help which wire should i cut???
Street Corner
yes i searched and searched and searched and no one seems to be able to tell me. i have 4 wires that go to the fuel pump 2 black with little grey circles on them, a yellow one with grey circles, and a yellow one with grey circles and a black line going down it... thats all...
teamdelsol.com lists red/green and blakc/white and all these other colors that i dont see, but i know that its a different car so im not suprised they are different... (oh i have a crx hf if you didnt know.)
what i dont know is some talk about cutting the power wire then some talk about cutting the ground so which one should i cut? and if the suggestion is the ground... which ground? they look the same too me unless im not looking close enough... please help me out if someone already has done this one thier crx let me know which one to cut, everything else i think i got taken care of just that little problem thanks
i put it here because this is kind of a specific car question but if yall think it should really be in security then i guess move it over there. thanks
Street Corner
thats the power one correct? i heard it was bad to cut the power wire something about it could burn your switch up i dont know... did you use any kind of relay? or is it just connected to a hidden switch? by the way thanks for the responce
you should cut the ground in m opinion... which ground i am not totally sure... i got a helms in my garage and i will look it up tomorow when i get a chance... anyway it is the ground you should cut... if you cut the power it will work to (it will stop the power to the pump) but you are also taking a chance at damaging your pump... maybe if you put a relay or fuse box then you would be safe.. but i am not sure... i will check and find out for you... also you might want to post in the security section they might be able to help you too... but i will try and see if i got something... good luck
Kcalb Semaj
Nov 25, 2003 05:22 AM
moofoo
6
Aug 19, 2002 08:07 AM
