crx swap
Old Apr 10, 2004 | 04:47 PM
SunsetLude's Avatar
SunsetLude
Default crx swap
in a crx swap does the motor drop from the bottom or do u pull it from the top
Old Apr 10, 2004 | 05:38 PM
rexerin's Avatar
rexerin
beep! beep!
engine crane pulls it out from the top
Old Apr 10, 2004 | 06:29 PM
cwood1388's Avatar
cwood1388
yeah pull it from the top
Old Apr 10, 2004 | 08:57 PM
Redlinerz's Avatar
Redlinerz
You can do either actually...It depends on the equipment you have...I have done them both ways though and I personally think it is sometimes easier to do from the top..
Old Apr 11, 2004 | 09:33 AM
SunsetLude's Avatar
SunsetLude
ok thanks yall.. ive just heard both i wanted to be sure.. me and my brother are putting a ZC in his 91 crx
Old Apr 11, 2004 | 10:43 AM
jaje's Avatar
jaje
HC Racer H5
i've done it both ways...under was better to install and remove (much easier to position as both the engine and car were level) but you need a shop with a car lift...with a cherry picker it was harder to put in (even with a leveler)...but once you get used to doing it becomes 2nd nature
Old Apr 11, 2004 | 01:19 PM
SunsetLude's Avatar
SunsetLude
yah my dads a master tec hes done stuff from Geos to vipers so ill tell him the bottoms ezer thanks man
Old Apr 11, 2004 | 09:58 PM
A_PHOBIA's Avatar
A_PHOBIA
i did not do my swap.but im 95% sure that you can do either.the stock motor is small enough, to lift the car up around it with a lift. but most people dont have access to a car lift at there homes so they borrow an engine crane or buy one for around $170 bucks .....oh sh!t im a little late oh well.
Old Apr 12, 2004 | 06:26 AM
eastonball's Avatar
eastonball
I prefer to do it from the bottom. Drop it out the bottom, and put it up from the bottom of the car, and use an Cherry picker to lift it up through the engine bay. It's a lot easier getting the mounts to line up.
compfreak2002
CRX & Pre 92 Civic
9
Apr 1, 2004 03:17 PM
raiden571
CRX & Pre 92 Civic
2
Oct 31, 2003 08:49 AM
Zedron
Engine Swaps, Tech & Tuning
4
May 12, 2003 09:11 PM
Lemonhead
CRX & Pre 92 Civic
3
Nov 12, 2002 02:07 PM
crxsiperf
CRX & Pre 92 Civic
3
Oct 22, 2002 06:25 PM
