syncro grind
Old May 3, 2005 | 01:01 PM
90_crx_flaze's Avatar
90_crx_flaze
Drift King
Default syncro grind
does anyone know where to get new syncros, like some performance ones or somethin, i went to the dealership and they wanted me to buy a new tranny and were complete assholes to me
Old May 3, 2005 | 01:52 PM
Exempt's Avatar
Exempt
2 tone Rex
Find a good used tranny... Or a rebuilt one... Thats probably your best bet... I dont think its cost efficient to rebuilt one yourself...
Old May 3, 2005 | 03:53 PM
90_crx_flaze
Drift King
i was thinkin about building up something that wont be at redline barrying the speedo in fifth, i wonder how fast my car can go
Old May 3, 2005 | 05:36 PM
Exempt's Avatar
Exempt
2 tone Rex
Ah, if thats the case then yea, go for it... Not sure where to get parts... I think u need a final drive from a DX tranny? Not sure tho...
Old May 3, 2005 | 07:24 PM
Kai's Avatar
Kai
Rotorphile.
Have you ever had a trans apart? It's a lot more difficult then just opening it up, replacing the synchros, and bolting it back together. If you want it to last for more then one thousand miles, that is.
For grinds, I like to replace the trans oil a couple times, allowing about a thousand miles between changes. If it's just as bad, it's time for a used or rebuilt trans. D-series engines don't put out neary enough power to justify a performance trans, mind you when you say "performance" I think multi-thousand dollar dog boxes.
Old May 4, 2005 | 05:18 AM
aftershock192's Avatar
aftershock192
check out a company called speedgear(i think) for carbon coated syncros. I take it an SI tranny you could replace fifth gear with an HF gear. Another choice would be to coat the parts in an antifriction coating (swain coatings should be able to do it).
Old May 4, 2005 | 06:30 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
coat SYNCROS in an ANTIFRICTION coating?
That would totally ruin the entire point of a syncro.
Gearspeed uses carbon syncros BECAUSE carbon is a good friction material, and they reduce downshift jump due to them getting to speed quicker.
Old May 4, 2005 | 07:15 AM
Illegal B16's Avatar
Illegal B16
New Zealand
what tranny fluid are you useing to begin with...most people i know it ends up being the wrong tranny fluid, I.E. regular oil, or the clutch/fly.
Old May 4, 2005 | 12:44 PM
90_crx_flaze
Drift King
oh buddy im using 10-w40 right now, for highway use, thats almost the same as the hondaMTF, im not an idiot like 4 people in my town and put that 80-90 gear shit in there blown out 2 trannys and about the be 4 more, i told them to get MTF or at least 10-w30 or 40
Old May 4, 2005 | 10:26 PM
Illegal B16
New Zealand
you need to put in honda tranny fluid before you assume that your syncros are bad.
