wiring help
Old Feb 6, 2006 | 02:46 PM
Wiringmess's Avatar
Wiringmess
Default Audio wire nightmare
Its sorta simple really ive never had this problem in any civic ive owned but i got a 1989 honda civic hatchback DX and ive attempted to install my radio but the previous owner had cut the wires so i did it manualy and as far as the radio it works but when i shut the car off it losses memory so ive got the ACC wire hooked up and the only way the radio will work is if i hook the 2 ACC wires and the batt. Mem wire up togather ive used a test light and can not find no live wire to support memory for when i shut the car off im at a complete loss and i can not find a wiring Diag online can anyone help? you can post a reply or email me at OrlandoSuxx@aol.com thank you!!
Old Feb 6, 2006 | 03:24 PM
jlicrx's Avatar
jlicrx
here are wiring pinouts - i have diagram if you need it
File Type: jpg
Old Feb 6, 2006 | 03:30 PM
Wiringmess's Avatar
Wiringmess
well i have the pin outs my main problem is what wire is the Batt.Mem , well ill try this again i have a pioneer iver hooked all the wires up top that diag u showed but my problem is that i lose my memory when i shut the car off and the only way i can get the radio to work is if i hook up the Batt.Memory wire from the radio to the ACC wire to the car so thats a total of 2 wires that i half to run to the ACC wire from the car inorder to get the radio to work but i still loses memory cause its not a constant power source, i hope this helps more
Old Feb 6, 2006 | 03:49 PM
Wiringmess's Avatar
Wiringmess
i just studyed that diag u showed me but the problem is it doesnt match upp 100% cause the Main stero power supply isnt whte/green its yellow/red well its the only live wire when the car is on
Old Feb 6, 2006 | 06:05 PM
Wiringmess's Avatar
Wiringmess
Ok also let me just add this there is NO Orig. wire harness wired into the car just spliced wires
Old Feb 6, 2006 | 07:06 PM
ChrisS's Avatar
ChrisS
Look for a white w/blue stripe wire that should be always hot.
(I went throught the same thing with my CRX; some fool cut the connector for the radio off the wiring harness.)
Old Feb 6, 2006 | 07:56 PM
ChrisS's Avatar
ChrisS
Without the original wiring harness, try this:
-turn the ignition key to off
-connect the ground clamp of your circuit power tester to ground
-test each fuse under the steering wheel (looking for one that remains hot with the car completely off)
I think, the fuse (circuit) that supplies the ECU's memory is always hot.
Old Feb 7, 2006 | 03:29 AM
Wiringmess's Avatar
Wiringmess
when the car is off there is no hot wire at all and the radio fuse under the dash is fine
Old Feb 7, 2006 | 03:58 AM
waaBAAH's Avatar
waaBAAH
thjis sounds good to me.....maybe it is tucked...or cut really short.
also....it is really hard to read your posts. i almost fainted from not breathing since you dont have any punctuation.
Old Feb 7, 2006 | 04:55 AM
Wiringmess's Avatar
Wiringmess
No i found the w/blue wire. and it is not hot!!!!!!!!
