Does Anyone Have a Similar Setup?
Does anyone have as setup that is similar to this? I will be finishing my project this up coming week. What should I expect to run from this? Well let me know if you got any imput.
Engine:
JDM B16a1 Swap
3" Intake
AZ Race Motor Mounts
B&M Fuel Pressure Regulator
Crane Cams Ignition Wires
GSR Water Pump
ITR Injectors
ITR Throttle Body
Koyo Racing Radiator
MSD Blaster SS Ignition Coil
MSD Pro Distributer Cap
NGK V-Power Spark Plugs
Skunk 2 Short Shifter
Tanabe Racing Medallion Exhaust
Head:
3 Angle Valve Job
ARP Head Studs
Billet Spark Plug Cover
CTR Cams
Hondata Intake Manifold Gasket
KMS Silicon Bronze Valve Guides
OmniPower Retainers
Port & Polish
Port Matched
Skunk 2 Dual Valve Springs
SuperTech Valves
Toga Performance Valve Seals
Type-R Valve Cover
Block:
King Performance Racing Main Bearings
King Performance Racing Rod Bearings
Type-R Crank Pulley
Type-R Pistons (CTR)
Transmission:
S1 Tranny
F1 Racing Stage 2 Clutch
Fidanza Aluminum 7.5lb Flywheel
Suspension:
Drop Zone Camber Kit
Front Tie Bar
Rear Tie Bar
Rear Strut Bar
Skunk 2 Coilovers
Titan Tower Strut Bar
Tociko HP Shocks
Electronics:
Apexi VAFC 2
Custom Engine Wiring Harness
Mugen Chip ECU
Engine:
JDM B16a1 Swap
3" Intake
GSR Water Pump
ITR Injectors
ITR Throttle Body
Head:
3 Angle Valve Job
ARP Head Studs
CTR Cams
OmniPower Retainers
Port & Polish
Port Matched
SuperTech Valves
Type-R Valve Cover
Block:
Type-R Crank Pulley
Transmission:
S1 Tranny
Suspension:
Front Tie Bar
Rear Tie Bar
Rear Strut Bar
Skunk 2 Coilovers
Tociko HP Shocks
Electronics:
Apexi VAFC 2
Mugen Chip ECU
