crx dohc zc head shave
Old Dec 15, 2005 | 08:23 AM
u5el355's Avatar
u5el355
Default crx dohc zc head shave
hi,i have a dohc zc swap and i was wondering how much you can shave off the head without piston to valve.i have adjustable cam gears and stock head gasket.thanks
Old Dec 15, 2005 | 09:08 AM
jlicrx's Avatar
jlicrx
check your PM
Old Dec 15, 2005 | 12:42 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
I would be more concerned with timing.
Old Dec 23, 2005 | 06:18 AM
u5el355's Avatar
u5el355
i have aem adjustable cam gears so setting the timing shouldnt be an issue.
should it?
Old Dec 23, 2005 | 04:03 PM
Kai's Avatar
Kai
Rotorphile.
Not much... I wouldn't trust them shaved any more then a standard resurface job.
Why do you want to shave it? There are much better ways to make power out of a ZC (or any engine, for that matter) then shaving the head.
Old Dec 25, 2005 | 01:50 PM
u5el355's Avatar
u5el355
i want to make 200hp all motor, and still be a daily driver.
Old Jan 5, 2006 | 01:22 AM
1RedLude's Avatar
1RedLude
I shaved mine .040 without issue. Still a lot of the buttons left. Just look at that combustion chamber and the huge lip on it. There's plenty to shave. Someone on ZCR shaved theirs .080 and decked the block .030 without any valve/piston clearance issues.
Old Jan 7, 2006 | 02:20 AM
Kai's Avatar
Kai
Rotorphile.
Two hundred horsepower, daily driven, out of a 1600cc engine. Yeah, right.
Old Jan 7, 2006 | 02:49 AM
1RedLude's Avatar
1RedLude
Yeah....200whp N/A might be a bit of a stretch. I won't disagree with ya there.
Old Jan 7, 2006 | 06:48 AM
u5el355's Avatar
u5el355
200 hp with cams headwork and hondata ecu?
I think i may have a good shot at it.
