dead 87 si
Old Feb 9, 2006 | 07:17 AM
foodog00's Avatar
foodog00
Default dead 87 si
my stock 87 crx si just died..turns over and there is spark from the coil and distributor..took valve cove off and all is moving there also..used starting fluid to see if it was a fuel issue and nuthin...help if u can..thanks
Old Feb 10, 2006 | 12:43 AM
Kai's Avatar
Kai
Rotorphile.
Did anything happen before it quit, or was it random?
Old Feb 11, 2006 | 07:16 AM
foodog00's Avatar
foodog00
just one day it wouldnt reach over 4 grand..acted like bog/rev limiter.. then a small clunk and erratic tach movent then nuthin..
Old Feb 11, 2006 | 07:19 AM
jlicrx's Avatar
jlicrx
sounds to me like it has bad igniter
Old Feb 11, 2006 | 09:36 PM
Kai's Avatar
Kai
Rotorphile.
Common test for the ingnitor: have a friend tap on it with a wrench while you try to start the car. Odd, but it works about as often as the starter/hammer trick does.
Old Feb 28, 2006 | 07:16 AM
foodog00's Avatar
foodog00
so once i fix it an get this runnin how do i keep it from happenin again? to replace that ignitor from local part store is like 200 bucks. any options? would hate to have it go out again and get stuck somewhere. fill me with you infinite wisdoms guys..
Old Mar 1, 2006 | 05:21 PM
Kai's Avatar
Kai
Rotorphile.
Get one from a junkyard for like $10.
Old Mar 10, 2006 | 06:26 AM
whitecrx88's Avatar
whitecrx88
the car jump timeing because if it wouldnt start with starter fluid then the timing is off for sure if you have spark.if thats not it try the main relay to.
