GSR head on an LS Block
Old 02-18-2006, 09:54 PM
90CvcDX
kekeke
90CvcDX's Avatar
Default GSR head on an LS Block
is this possible? i currently have a B18a1(2) block with a b16 transmission, and i want to change my head to at least a GSR head, i'm just wondering what i would need to do this? would i need the ecu seeing as how the GSR head is vtec?
Old 02-18-2006, 10:02 PM
AcuraFanatic
AcuraFanatic's Avatar
Yep, common setup, referred to as "LSVTEC"
You'd need the ECU, there's some machining work to tap the oil line into the block for VTEC operation. There's a kit from Golden Eagle you can buy to get all the neccessary hardware.
Do a search, it's been covered in detail on the board many a time.
Old 02-18-2006, 10:14 PM
90CvcDX
kekeke
90CvcDX's Avatar
Thanks for the info, i was expecting a flame but got info for a change :hugglez:
Old 02-19-2006, 03:26 PM
97civicEXVTEC
97civicEXVTEC's Avatar
AF must be in a good mood today. :chuckles:
Yes, it's been covered a lot so you should be able to find a lot of info if you search. LS-VTEC using a GSR head is said to be just like a b18c with more torque.
Old 02-19-2006, 08:12 PM
Driverman5777
Driverman5777's Avatar
Or you could also use a itr head or a civic b16a head.
Old 02-19-2006, 08:59 PM
AcuraFanatic
My personal experience is that the GS-R head is the best bang for the buck.
Old 02-19-2006, 09:20 PM
Driverman5777
And has the most potential, it flows a good deal better. So if its ported, polished and built it would do better than both.
Old 02-19-2006, 09:49 PM
sherwood
I missed Sean
sherwood's Avatar
-even if it doesnt flow better the GSR head has smaller chambers, it increases compression a good .2-.3 or so, which in itself can result in better numbers.
Old 02-19-2006, 09:57 PM
dubcac
I
dubcac's Avatar
It doesn't flow a good deal better...but it does flow slightly better, especially at full valve lift...and like sherwood said, provides higher compression.
Old 02-19-2006, 09:58 PM
90CvcDX
kekeke
90CvcDX's Avatar
Ok, so what would an ls/gsr/b16 motor hybrid be like then h: cuz that's pretty much what i'll be running if i do the gsr head swap. I'll probably get the head redone, change the internals of the block, and beef up the tranny a little, i want at least 250hp with FI. A good way to blow my taxes IMO
