swap help
Old Jan 31, 2006 | 04:10 AM
si-ripper's Avatar
si-ripper
Default swap help
i'm doing a swap on a 89 hb and want it to know if i need the splines or control arms and splines put help
Old Jan 31, 2006 | 09:13 AM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
If u have an hf, u need to swap your steering knuckles out for the si. If u have anything else but the hf, you don't need to touch the knuckles, the new axles should fit right in.
Old Feb 1, 2006 | 12:57 AM
si-ripper's Avatar
si-ripper
sorry bout that i'm doing a b18 swap on a 89 hb not a single swap
Old Feb 1, 2006 | 01:39 AM
RevengeCRX's Avatar
RevengeCRX
Oops sorry, didn't fully read that you're swapping into an 89 civic, not a crx. If u have a dx or si, you don't need to change your knuckles. If u have a std civic(which comes originally with a 4-speed manual transmission), then you'll need to swap your knuckles out with a dx or si's knuckles for the axles to fit.
Old Feb 2, 2006 | 03:36 AM
si-ripper's Avatar
si-ripper
i have a std so i need si knuckles for the ls axles to fit
