88 CRX when starting motor turns over and am getting spark.... If you keep trying it will finally crank runs till the key is turned off then will not recrank? Any ideas.... Also number one cylinder is closes to distributor ????
you may need a new ignition module which is in your distributor...or evn try cap and rotor wires and plugs, but my accord did that and it needed an ignition module
