Help with radiator fan plz
your fans are tied in to the oil pressure sensor in the back of the block there should be two wires that are covered by a plug that you take off and if you stick a wire in to them(loop one to the other) and turn your ingition on then they will turn on. They may be wired wrong, you may have them backwards or something. look to see if there is any other wires going to it.
