heater problems
Old Jan 15, 2005 | 11:18 AM
89crxinprogress's Avatar
89crxinprogress
Default heater problems
here's the deal. i have an 89 crx hf but the heater doesn't blow hot at all. i think my heater core may be bad. is there anyway to check it or do i just have to replace it and see what happens? i am going to check my chilton's book tonight and see if i can figure something out. any advise would be greatly appreciated...!
Old Jan 15, 2005 | 11:57 AM
teg92's Avatar
teg92
WHAT OK YEAH!
could just be the thermostat
Old Jan 15, 2005 | 01:16 PM
ChrisS's Avatar
ChrisS
-set the heater to maximum hot
-warm the car up
-turn off the motor
-open the hood
-feel the heater hoses
if they're hot, the heater core is working correctly (see air mixture instructions, below)
If they're cold, the core is probably plugged up or the heater valve isn't adjusted properly or is disconnected from the control cable
Air mixture instructions:
If the heater hoses were hot, the air mixture door on you car's heater module is not adjusted properly or not working at all. (on my 1991 crx si, the mounting point of the air mixture control cable at the heater control dial broke loose; I drilled a 1/8" hole and zip tied the cable back into position which fixed my heater problem.)
The other end of the air mixture cable is on the passenger side near where their left foot rests. Check to see if it's connected to the door; adjust it by setting the heater to max heat, loosening the clip holding the cable, and moving the cable so the door is providing air from heater core only, then tighten the clip.
(note: the manual says to check the heater valve cable adjustment after adjusting the air mixture cable.)
Old Jan 16, 2005 | 07:48 AM
89crxinprogress
thanks guys. i will give it a try and see what happens...
