can this be replaced?
Old Nov 27, 2004 | 10:28 PM
augy's Avatar
augy
Default can this be replaced?
I had noticed that the steering wheel on my ef hatch was loose, so I pulled off the H logo and tried tightening the nut, but it wouldn't catch. So I take off my wheel and find that the nut doesn't thread over the steering shaft AT ALL. It will slip right over it. So, I need to know if the top piece of the shaft is replaceable. I've attached a pic of the shaft with the nut on it.
I don't know how an aftermarket steering hub secures itself to the steering shaft, so I'm not sure if that will fix my problem.
So take a look at the pic if I haven't been clear enough and let me know if you happen to know whether the tip of the steering shaft (pictured) is replaceable. I took the pic at night with a flashlight and my camera phone, so the quality ain't so great.
augy
File Type: jpeg
Old Nov 28, 2004 | 04:23 AM
ED9man's Avatar
ED9man
driver
You might be able to rethread it with a tap and dye.
Old Nov 28, 2004 | 11:39 AM
Kai's Avatar
Kai
Rotorphile.
I doubt you can get that off... you will probably need a new steering column.
Trying a die of one thread size smaller and a new nut to fit would be the best thing try try first off.
Aftermarket hubs are still secured by that nut, so that won't help.
Old Nov 28, 2004 | 10:51 PM
augy's Avatar
augy
Cool. thanks guys.
