B16 question
Old Nov 18, 2004 | 08:20 AM
NoXqcs's Avatar
NoXqcs
Default B16 question
I have a Crx with a B16a swap, what aftermarket header will fit best , I don't want to use a 4 into 1 because of clearence issuses. I did a search of this forum but no clear answer was given. I think a DC sports for the 99-00 civic Si is my only choice, but would like more opinions please. Thank You.
Old Nov 18, 2004 | 12:57 PM
Kai's Avatar
Kai
Rotorphile.
Any modern B-series will bolt up, but you should stick to B16A block height ones:
-92-93 Integra GS-R
-94+ del Sol VTEC
-99-00 Civic Si
The main difference would be in the length after the final collector. You'll probably need an extension pipe made or your exhaust trimmed back to fit.
Old Nov 22, 2004 | 07:25 PM
jpdrag-on's Avatar
jpdrag-on
I have a 99-00 header 1 piece header and it sits too low so this one don't fit right, I just have the stock one for right now.
Old Nov 23, 2004 | 07:51 AM
1990CivicSi's Avatar
1990CivicSi
What about 94-99 gsr? I'm having the same issue.
Old Nov 23, 2004 | 07:57 AM
Kai's Avatar
Kai
Rotorphile.
Use a B18* pattern header.
90-01 RS/LS/GS/LS-S/SE
94-01 GS-R
Length below the oilpan also varies by year and model.
Old Nov 23, 2004 | 08:11 AM
Civic2Scooby's Avatar
Civic2Scooby
how can you use a 94+ header on the gen one crx....doesnt the gen one have the dual o2 sensors mounted in the header?
Old Nov 23, 2004 | 08:17 AM
1990CivicSi
Thaks, Kai. So which one would be best to bring it up off the ground?
Old Nov 23, 2004 | 09:25 AM
Kai's Avatar
Kai
Rotorphile.
I never considered adding or plugging an O2 bung to be that big of a deal. :dunno:
For example, the later GS-R's had two cat-mounted O2's... if you can get one of those headers for cheap, you might as well grab it and weld in an extra O2 bung or two if needed.
No idea on specific models.
Old Nov 24, 2004 | 03:44 PM
Civic2Scooby
you are gonna weld a bung into a cast manifold...:eh:
Old Nov 24, 2004 | 04:30 PM
Kai's Avatar
Kai
Rotorphile.
I've never seen an aftermarket cast iron header for a Honda.
