need to raise up alittle bit. spring/strut spacers?
Old Nov 20, 2004 | 07:23 PM
gutterslide's Avatar
gutterslide
Default need to raise up alittle bit. spring/strut spacers?
i got a 90 civic wagon on H&R Sport/Tokico Illuminas/Yokohama 195/60/15 and it's rubbing the inner and outer fender wells on sharp turns. i don't want to roll the fender edge and take a mallet to the inner well just yet. i figure the only other easy way around it (while keeping the same springs/wheels/tires) is to raise it up about 1/2". i wouldnt' mind doing this anyway, since the front is much lower than the rear as it is.
i've seen these "spring boosters" and "spring spacers", basically a hunk of neoprene rubber that fits between 2 coils of the spring to raise it up a bit. seems like a good idea.
i was also wondering about putting a 1/4" custom steel spacer between the top of the strut assembly and the chassis, but i don't know if this is a good idea. seems like it might put undue stress on the bolts.
anybody know anything about these options?
thanks.
Old Nov 21, 2004 | 06:24 AM
oneslowrex's Avatar
oneslowrex
The easiest thing you could probably do would be to change your tires to a 195/50/15. The 60's that you have on there now are just a bit to tall for being lowered. I've had two lowered crx's and the first was with Ground Control Coilovers and KYB AGX's and even cranked way down I barely ever rubbed. Using spacers and/or spring inserts has just never ever seemed very safe to me.
Old Nov 21, 2004 | 09:16 PM
gutterslide
ok.. i picked up some of the rubber spacers, but they're a no go. they won't fit in between the springs. i'm sure the aluminum twist-in type would work, but they don't seem like they'd feel too good, and might screw up the springs.
so, i'm seriously considering a 1/4-1/2" steel spacer to fit between the top of the strut assembly and the chassis. i know some european cars use these from the factory.. Volvo and BMW, i believe.
does this sound too disasterous to anybody?
Old Nov 22, 2004 | 11:10 AM
Kai's Avatar
Kai
Rotorphile.
Spring spacers are a serious band-aid. I'd recommend against using them.
You should seriously consider selling your springs and picking up some coilover type springs.
Old Nov 22, 2004 | 11:32 AM
Nelson's Avatar
Nelson
Administrator
Totally agree...
Just sell them and get a higher spring.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
