CV joint AXELS
Old Jan 3, 2005 | 09:01 PM
91_CiViC_RiDeR's Avatar
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Default CV joint AXELS
Ok I am soon to be changing my axels here in a month cause I can not take the unbearable clicking and clunking noise when I turn so I need to know how many splines are they....I have a 91 Civic DX 4 speed Manual...Also do tie rods usually come with the axels or will I have to buy them separately or what???
Thanks In Advance!!!
Old Jan 4, 2005 | 05:19 AM
gutterslide's Avatar
gutterslide
i don't think you will know how many splines until you take them out (thanks, Honda!). i could be wrong.
and why would tie rods come with the axles??
Old Jan 4, 2005 | 02:07 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
oh ok...DAMN IT>>>>> Well what I was trying to ask since I got a little bit of sleep since then is...Is it a good idea to replace your tie rods even if they are not worn out when you replace your cv joint axles????
Old Jan 9, 2005 | 04:39 PM
stankewj's Avatar
stankewj
I am looking to do the same work on a 90 HF next weekend. If you got any good advice since posting please forward.
Thanx.
Old Jan 9, 2005 | 05:02 PM
S2Kev's Avatar
S2Kev
If you replace your tie rods, you will need an alignment. Do you want to spend more money? If it ain't broke, don't fix it, I always say. :rick: Well unless it is preventive maintenance.
Old Jan 9, 2005 | 06:10 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Well in my opinon if you buy a car that is 13 to 15 yrs old and you do not know the complete mantienance of the vehicle then I would suggest on replacing anything neccessary to your needs and this is neccessary to my needs and besides since I am going to be replacing my cv joints then why not go ahead and replace my tie rods as well and alignment isn't anymore than 50 to 75 bucks here so I am going to go ahead and do it....But thanks for the help!!
Old Jan 9, 2005 | 09:43 PM
S2Kev's Avatar
S2Kev
You know you can check to see if the tie rods have play. Hold the wheel at 9 and 3 o' clock and move your arms forward and backwards.
Old Jan 9, 2005 | 09:49 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Thanks I will do that....That might save me a little bit of cash ....lol
Old Jan 9, 2005 | 11:33 PM
Kai's Avatar
Kai
Rotorphile.
I wouldn't bother replacing the tie rod ends now if you don't need them. It's not that hard to get the car on stands and apart.
There are two spline counts in the fourth generation, the lower of the two is what you'll need. The actual number escapes me.
Old Jan 28, 2005 | 02:51 PM
MIRRAdekcpe's Avatar
MIRRAdekcpe
Default .
yea, they are right......unless you're tie rods are bent, you don't need new ones.....just get new bushings...
on the spline count, the dx differs from the si, not for sure, but i think the dx is a 19 spline and the si is 21 spline.
