si tranyn on zc motor
Old Jan 13, 2005 | 05:46 PM
kevo2k6's Avatar
kevo2k6
Default si tranyn on zc motor
will the tranny of my 87 crx si bolt up to a zc motor? are all si tranny's the same?
Old Jan 13, 2005 | 06:03 PM
jlicrx's Avatar
jlicrx
no, transmission will not bolt to ZC - 85 Si transmissions have different gearing than 86-87 - 88-91 Si transmissions are completely different from 85-87 - 92 & up Si is also different from the earlier ones
Old Jan 13, 2005 | 06:22 PM
kevo2k6's Avatar
kevo2k6
y does the gearing matter? shouldnt it just be the bolt pattern? and then a flywheel and clutch?
Old Jan 13, 2005 | 06:26 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Tranny's are way more complicated than that from my understanding. Of course that's not to say that I understand transmissions. I'll prolly never fully understand em.
Old Jan 13, 2005 | 06:42 PM
Mackenzie C's Avatar
Mackenzie C
i dont know bout the pre 88 models but the 88-91 trannys are all interchangable. and for the clutch you need to check out the flywheel on the zc or something, i dont know.
Old Jan 14, 2005 | 01:33 AM
Kai's Avatar
Kai
Rotorphile.
No.
No.
Old Jan 14, 2005 | 11:50 AM
kevo2k6's Avatar
kevo2k6
so a 88-91 si tranny WILL work tho?
Old Jan 14, 2005 | 11:51 AM
kevo2k6's Avatar
kevo2k6
o and im gettin the zc motor and ecu. will i need a new wiring harness as well?
Old Jan 14, 2005 | 02:38 PM
Kai's Avatar
Kai
Rotorphile.
It will work on the engine, but it won't work in your car.
I hope you mean an 84-87 browntop ZC. Typical 88-91 blacktop ZC's are not bolt-in swaps.
Old Jan 14, 2005 | 09:16 PM
kevo2k6's Avatar
kevo2k6
wat trannys will bolt up and work with the zc motor? regardless of wat car it is going into.
